RequireJS and ArcGIS API for JS
16033
10
05-13-2015 08:46 AM
EvelynHernandez
Idk if im in the correct forum asking this , but idk where can i ask for people that it is just starting to change to js language.
I am following a basic requireJS tutorial that i found in this link​ and following the steps im trying to put in the require.config path the latest api.
("https://js.arcgis.com/3.13 ")
but idk how is the structure in the require to call all the functions that i need to use the examples showed in the samples website for arcgis for js.
Ex: Create a map | ArcGIS API for JavaScript
The thing is i dont want to put the require in the same webpage, so im using the structure how the attachment shows.
My html just have this in the head.
<script src="js/require.js" data-main="js/main"></script>
My main.js file is something like:
require.config({
  paths: {
    'esri': 'https://js.arcgis.com/3.13'
require(['order!jquery','esri','esri/Map', "dojo/domReady!"], function ($, Map) {
What im doing wrong or missing?
Thanks for all ur help as always
JeffJacobson
"I can't post a jsFiddle with external file resources..."
FYI, Plunker will let you do this.
