Require a method to call a URL World_Imagery (MapServer) from client site without redirecting request to proxy.jsp file at server
1313
07-28-2016 05:07 AM
AdarshSharma
we are using proxy for token services but our web application server not having a internet connectivity because of which it is unable to call URL World_Imagery (MapServer)
Please suggest a method to call this URL World_Imagery (MapServer) without using proxy.jsp & other URL is (10.131.5.244:6080/arcgis/rest/services).
NOTE- we cannot allow internet to our hosting server for security reasons.
Call proxy in my javascript :-
esri.config.defaults.io.proxyUrl = "proxy.jsp";
esri.config.defaults.io.alwaysUseProxy = true;
esriConfig.defaults.io.corsDetection = false;
proxy.jsp :-
<%@page session="false"%>
<%@page import="java.net.*,java.io.*" %>
String[] serverUrls = {
"http://myserver.mycompany.com/arcgis/rest/services,ayn2C2iPvqjeqWoXwV6rjmr43kyo23mhIPnXz2CEiMA6rVu0x..."
"https://server.arcgisonline.com/ArcGIS/rest/services",
  "http://10.131.4.244:6080/arcgis/rest/services,55diNsb4PSZW1pf9MDkTJ1ZGfLDUhc6rn81rg-bIszh9RRN3mi6Imw..."
try {
  String reqUrl = request.getQueryString();
  boolean allowed = false;
  String token = null;
  for(String surl : serverUrls) {
    String[] stokens = surl.split("\\s*,\\s*");
    if(reqUrl.toLowerCase().contains(stokens[0].toLowerCase())) {
      allowed = true;
      if(stokens.length >= 2 && stokens[1].length() > 0)
        token = stokens[1];
      break;
  if(!allowed) {
    response.setStatus(403);
    return;
  if(token != null) {
    reqUrl = reqUrl + (reqUrl.indexOf("?") > -1 ? "&" : "?") + "token=" + token;
  URL url = new URL(reqUrl);
  HttpURLConnection con = (HttpURLConnection)url.openConnection();
  con.setDoOutput(true);
  con.setRequestMethod(request.getMethod());
  if(request.getContentType() != null) {
   con.setRequestProperty("Content-Type", request.getContentType());
  con.setRequestProperty("Referer", request.getHeader("Referer"));
  int clength = request.getContentLength();
  if(clength > 0) {
  con.setDoInput(true);
  InputStream istream = request.getInputStream();
  OutputStream os = con.getOutputStream();
  final int length = 5000;
   byte[] bytes = new byte[length];
   int bytesRead = 0;
   while ((bytesRead = istream.read(bytes, 0, length)) > 0) {
     os.write(bytes, 0, bytesRead);
  else {
    con.setRequestMethod("GET");
  out.clear();
  out = pageContext.pushBody();
  OutputStream ostream = response.getOutputStream();
  response.setContentType(con.getContentType());
  InputStream in = con.getInputStream();
  int bytesRead = 0;
  while ((bytesRead = in.read(bytes, 0, length)) > 0) {
    ostream.write(bytes, 0, bytesRead);
} catch(Exception e) {
  response.setStatus(500);
