Render output from custom equations
928
10-12-2010 07:39 AM
DonaldCatanzaro
Hi All,
I am trying to figure out if I can use ArcGIS JavaScript for my application and as a newcomer I have been unsuccessful as of yet so I am turning to the forum.
I want to deliver to my user a mapping application with some source data and I want to give them the flexibility of running a regression equation on the source data where they have the flexibility to choose cut-points or other options.  Once their choice is made, the output would be displayed on as a map (along with other associated data).
I know I can complete the regressions using JavaScript (there is lots of code on the web) - the issue is more along the lines of getting that regression output to the map display.
This seems to be slightly different than many samples and much of the code I have seen but I suspect I am searching using the wrong terminology.  So I guess I am asking if someone could point me to some resources that might allow me to figure this out.
I know I can do this in Java and I suspect (but don't know about Flex).  I kinda like the JavaScript API so I figured I would start here.
Thanks in advance !
-Don
DonaldCatanzaro
Hi All,
I found this link:  http://www.thinkmoney.com/mortgage/mortgage-calculator/ which is a mortgage calculator that is slider controlled.
I basically want something like this but instead of "Interest only mortgage" or "Repayment mortgage" the output would be values for my polygons which I could then colorize and display as a map.
Thanks again !
-Don
