Remove Swipe
2020
10-15-2020 11:56 AM
cadgism
Swap widget (4.16) is working fine. When finished,  I want to give the user an option to remove the swipe and bring then map view as it was before swipe. I tried
swipe.visibleElements = {
      divider: false,
      handle: false // handle will not display
swipe.destroy(); .
Still the handle and divider are visible. How can I remove the swipe and refresh the view please/ Thanks.
AnneFitz
Swipe.destroy() should work to remove the swipe widget from the view.
Here's an example - https://codepen.io/annefitz/pen/dyXGxqz
You can also try setting swipe.view to null. This should remove the swipe widget from the view without destroying the Swipe widget completely. Hope this helps!
AnneFitz
