Remove "segment-select" event in Directions dijit js api
1591
12-19-2017 01:37 AM
AlbertoLópez
Hello;
I have to insert some td html elements in the results table of the Directions dijit (version 3.22) and I need to remove  the "segment-select" event of  the Direction dijit.
What I want is that when I click on any of the segments of the direction table results, the map view does not move to the selected segment in the map
I have tried to do this in the direction finish event  function and in the startup function of the widget  but without results.
1-
var buttonHandler = on.pausable(this._dijitDirections, "segment-select");
buttonHandler.pause();
2-
var buttonHandler = on(this._dijitDirections,'segment-select', lang.hitch(this, function (evt) {
buttonHandler.remove();
3-
4-
this.own(on(this._dijitDirections, 'segment-select', lang.hitch(this, function (event) {
event.stopPropagation();//and event.target.stopPropagation()
Any suggestions?
Best Regard.
RobertScheitlin__GISP
Alberto,
  OK that is quite a bit more complicated. You have to override the Directions dijits centerAtSegmentStart function:
Add the new require to your require array:
require([
  "dojo/Deferred",
], function(
  Deferred,
set the dijits centerAtSegmentStart override function:
directions.startup();
directions.centerAtSegmentStart = _centerAtSegmentStart;
Here is the override function:
        function _centerAtSegmentStart(a) {
          var b, d = new Deferred;
          if (directions.directions && directions.directions.features) {
              b = Math.max(0, Math.min(directions.directions.features.length - 1, a || 0));
              var e = directions.directions.features[b];
              directions.highlightSegment(b, !0);
              directions._showSegmentPopup(e, b);
              d.resolve()
          } else
              d.reject(Error("No directions."));
          return d.promise
Alberto,
   You can remove the listeners this way:
        directions.on('directions-finish', function(){
          query('.esriRoute', this._dijitDirections.domNode).forEach(function(item){
            item.outerHTML = item.outerHTML;
AlbertoLópez
Thank you very much Robert.
Your code works fine , but in addition to remove  the segment-select event, it also removes the segment-highlight event (Fired when you hover over a route segment in the directions display.). I need to remove only the segment-select event but not the segment-highlight .
It's possible?.
Regards.
Alberto,
require([
  "dojo/Deferred",
], function(
  Deferred,
              d.resolve()
          } else
          return d.promise
