Refresh Feature table based on visible layer?
3207
05-23-2016 01:44 PM
NMWater
Hi ,
I have six layers, they all have the same Field names, and I want to connect them based on the feature layer that is currently visible. Do I need to add a destroy() or refresh() every time I change a layer?
Thanks!
var layer = function changetable() {
     if (CNTYmm.visible)
               {var layer = CNTYmm}
     else if (HUC8mm.visible)
               {var layer = HUC8mm}}
myFeatureTable = new FeatureTable({
  "featureLayer" : layer,
  "outFields":  ["NAME", "Units"],
  "map" : map,
  "gridOptions" : {
  allowSelectAll: true,
  allowTextSelection: true,
   }, 'PrecipTable');
JeffJacobson
Yes, that is exactly what you need to do. I have heard that this will no longer be necessary at v. 3.17 of the API, though.
NMWater
Hi Jeff!
Thanks for your response! I still haven't had much luck with this but I believe it is a syntax issue. Just to clarify, I can do this with one Feature Table and not six? Also, any idea on when 3.17 is coming out?
Many Thanks!
ChristopherJohnson1
Any further update on this?
Thanks...Chris
