Rectangle and Lasso selection tools not showing in 3D
1347
04-28-2023 01:02 PM
CalebSchwind
Is there a way to have the rectangle and lasso selection tools show up in 3D? They show up in 2D and work fine, but they are hidden in 3D.
I created a couple of codepens to illustrate the issue. The code is exactly the same except the 3D codepen uses SceneView instead of MapView.
https://codepen.io/cschwind/pen/KKGvwrm - 2D works as expected
https://codepen.io/cschwind/pen/VwEzYxg - 3D selection tools not visible
SaschaBrunnerCH
This is a known limitation and is not supported at the moment for 3D.
SaschaBrunnerCH
CalebSchwind
Thank you for the quick response.
