ReactJS Typescript
1649
6
10-23-2025 07:20 AM
vijaybadugu
Is there any help online documentation for mapcomponents react js ?
DavidSolari
MVP Regular Contributor
If you're asking how to embed the new SDK components in a React component, the official docs go over how to render them and pass in data to their attributes. Once you hit a wall you can post about the specific component/attribute issue you're having and get focused help from there.
vijaybadugu
I created a separate component ActionBar.tsx , Which includes, Layers, Legend and basemap Gallerty
      <CalcitePanel
        ref={(el) => { panelRefs.current['legend'] = el; }}
        heading="Legend"
        data-panel-id="legend"
        closed={activeWidget !== 'legend'}
        closable
        onCalcitePanelClose={handlePanelClose}
        style={{ height: '100%' }}
        {mapRef && <ArcgisLegend legendStyle="classic" referenceElement={mapRef} />}
I have passed Map reference object and View object, Nothing is working. I was getting No Legend.
Justin_Greco
I'm thinking it should be mapRef.current instead of just mapRef.
vijaybadugu
I tried everything with no luck
Justin_Greco
Can you post the entire code for your component?
Since you are using React 19 and if this is a new app, I’d recommend not using the calcite-components-react wrapper.
ReneRubalcava
Esri Frequent Contributor
If you have a github repo, can take a look, but our samples don't use the react wrappers
https://github.com/Esri/jsapi-resources/tree/main/component-samples/map-and-charts-components-react
