reactiveUtils replacment for watchUtils.pausable
1603
08-18-2022 08:15 AM
RobertScheitlin__GISP
In watchUtils there is the pausable method what is the equivalent for reactiveUtils? Do I need to add and remove the watchHandle?
AndyGup
Hi Robert, correct, with reactiveUtils you would need to add or remove the WatchHandle. Or,  in the case of once() or whenOnce() since those return a Promise you would use AbortSignal. For the moment this is the most efficient pattern since the underlying API is tracking observable property access, rather than tracking individual values.
AndyGup
Thanks Andy.
