React-based compilation error (Module not found and JSX related)
4243
07-05-2022 05:01 AM
Anirban_Banerjee
(P1)
I started building an extremely basic WebMap with React (version: ^18.0) and ArcGIS APIs. I chose AMD modules instead of ES and used NPM as the package manager. I did not choose NPM but it did not install yarn (used: npx create-react-app-'name') and I kept using NPM.
I've created a Map.js script alongside the default App.js and imported Map.js into App.js.
Issue #1-
At first, I did not import the React (with R in upper-case) package into the App.js script but I imported Map into App.js, and normally, I installed the React package in Map.js. However, it threw this error-
 'React' must be in scope when using JSX react/react-in-jsx-scope
Then, I again, injected React into App.js to circumvent the issue (with no logic behind it). It was not showing the jsx error anymore but it created another problem, issue #2-
Module not found: Can't resolve 'Map.js' in 'D:\Workflow\Own\React_apps_GIS\reactmb\react_arc\src
Here, the module couldn't be found, which is a scripting error. I checked it but could not find any but there is obviously a problem.  I am seeking the community's help. I am posting the complete Map.js script below:
Code:
import React ,{useRef,useEffect} from 'react'
import {loadModules} from "esri-loader"
import MapView from esri/views/MapView;
import WebMap from esri/WebMap;
function Map() {
    const MapEl=useRef(null)
    useEffect(
            let view;
        loadModules(["esri/views/MapView", "esri/WebMap"],{
            css:true
        }).then(([MapView, WebMap])=>{
            const webMap= new WebMap({
                basemap:'topo-vector'
            view= new MapView({
                map:webMap,
                //center:[88.414, 22.5805],
                zoom: 11,
                //here, useRef=container
                container:MapEl.current
        return()=>{
            //close the map view if nothing in the view
          if(!!view){
            view.destroy()
            view=null
    return (
        //refers to the div style
        <div style={{height:500}} ref={MapEl}>
        </div>
export default Map
Packages:
  "name": "react_arc",
  "version": "0.1.0",
  "private": true,
  "dependencies": {
    "@arcgis/core": "^4.24.5",
    "@testing-library/jest-dom": "^5.16.4",
    "@testing-library/react": "^13.3.0",
    "@testing-library/user-event": "^13.5.0",
    "arcgis-js-api": "^4.24.5",
    "esri-loader": "^3.5.0",
    "react": "^18.2.0",
    "react-dom": "^18.2.0",
    "react-scripts": "^2.1.3",
    "web-vitals": "^2.1.4"
  "scripts": {
    "start": "react-scripts start",
    "build": "react-scripts build",
    "test": "react-scripts test",
    "eject": "react-scripts eject"
  "eslintConfig": {
    "extends": [
      "react-app",
      "react-app/jest"
  "browserslist": {
    "production": [
      ">0.2%",
      "not dead",
      "not op_mini all"
    "development": [
      "last 1 chrome version",
      "last 1 firefox version",
      "last 1 safari version"
@AndyGup, your suggestions?
AndyGup
Hi @Anirban_Banerjee we recommend using ES modules "@arcgis/core" with new React projects rather than esri-loader. Here is a working example: https://github.com/Esri/jsapi-resources/tree/master/esm-samples/jsapi-create-react-app
Anirban_Banerjee
Thanks, Andy. I was going to try it out but I inserted './' before Map.js. Then, it worked. Care to shed light on the logic?
