"Map only" print option
1151
01-19-2023 10:21 AM
LefterisKoumis
Is there a way to remove the "Map only" tab from the print widget?
Defining the layouts it only affects the options under the Layout tab.
const print = new Print({
  view,
  printServiceUrl:
    "https://XXX",
  templateOptions: {
    title: "",
    nnorthArrowEnabled: true,
    layout: "a3-landscape",
JoelBennett
MVP Regular Contributor
In the Print widget sample, if I add the following within the style tag, the "Map only" tab disappears:
.esri-print__layout-tab[data-tab-id="mapOnlyTab"] {
	visibility: hidden;
The same should work if you add it somewhere in your own CSS.
JoelBennett
	visibility: hidden;
