queryTask zoom to queryResult
8679
22
04-12-2016 05:19 AM
GoranTozievski
Hi im working on application that need to show linear route(static).Im getting the route but i cant make it to zoom to routeExtent.Here is my code.
require([
       "dojo/dom", "dojo/on",
       "esri/tasks/query", "esri/tasks/QueryTask", "dojo/domReady!"
        ], function (dom, on, Query, QueryTask) {
  var params = getUrlParams();
  var kiosk = params['kiosk'];
  var cel = params['cel'];
  var lang = params['lang'];
            queryTask = new esri.tasks.QueryTask("http://................................................................/MapServer/0");
            var query = new Query();
            query.returnGeometry = true;
            query.outFields = [
  var lang = 0;
  if(location.href.indexOf("_alb") > -1)
  lang =1;
  else if (location.href.indexOf("_en") > -1)
  lang =2;
  if(lang == '0'){
  queryTask = new esri.tasks.QueryTask("http://................................................................/MapServer/0 ");
  }else if(lang == '1'){
  else {
function executeRoute() {
  var nameKiosk ;
  if(kiosk == 1){
  nameKiosk = 1;
  if(kiosk == 2){
  nameKiosk = 2;
  if(lang == 0)
  query.where = "OD = '"+nameKiosk+"' and DO = '"+ime_objekt.innerText+"'";
  else if (lang == 1)
  query.where = "OD_AL = '"+nameKiosk+"' and DO_AL = '"+ime_objekt.innerText+"'";
  else
  query.where = "OD_EN = '"+nameKiosk+"' and DO_EN = '"+ime_objekt.innerText+"'";
  queryTask.execute(query, showResults);
  return false;
  function getUrlParams() {
   var paramMap = {};
   if (location.search.length == 0) {
  return paramMap;
   var parts = location.search.substring(1).split("&");
   for (var i = 0; i < parts.length; i ++) {
  var component = parts.split("=");
  paramMap [decodeURIComponent(component[0])] = decodeURIComponent(component[1]);
   return paramMap;
            function showResults(results) {
                var resultItems = [];
                var resultCount = results.features.length;
  var symbol = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([0, 255, 255]), 4);
  for (var i = 0; i < resultCount; i++) {
                    var graphic = results.features;
                        graphic.setSymbol(symbol);
                        app.map.graphics.add(graphic);
  var stateExtent = graphic.geometry.getExtent();
  app.map.setExtent(stateExtent);
                dom.byId("info").innerHTML = resultItems.join("");
                console.log(resultItems.join(""));
RobertScheitlin__GISP
Derek,
  I could see this working if the results had more than one feature in it. But the OP stated
The query always will show only 1 result
I am thinking a layout issue like thejus kambi
DerekNalder
The only other thing I can think of is to make sure the spatial reference of the result feature is the same as the map.
GoranTozievski
Same.. The route dont get the extent.
