querytask returns no errors but undefined variables!
6569
12
06-30-2015 04:42 PM
LefterisKoumis
This function returns undefined variable. The first alert returns: something found:1
the second alert returns "Odometer 1: undefined.
I have a very similar code shown below under GOOD CODE that it returns the expected value.
Both code execute the same querytask.
What's wrong in the first block code? Thanks.
function queryTask_odometer1_executeCompleteHandler(results)
  if (results.features && results.features.length > 0) {
  alert("something found: " + results.features.length);
  resultCount=results.features.length;
  for (var i = 0; i < resultCount; i++) {
  var featureAttributes = results.features.attributes;
  for (var attr in featureAttributes) {
  if (attr = "Odometer")
  { alert(attr + "1:  " + featureAttributes[attr]);
  }else{
  alert("nothing found");
  //alert(mydata);
GOOD CODE
function showResults (results) {
  var resultItems = [];
  var resultCount = results.features.length;
  alert (resultCount);
  resultItems.push("<b>" + attr + ":</b>  " + featureAttributes[attr] + "<br>");
       //   dom.byId("info").innerHTML = resultI
LefterisKoumis
THANK YOU. I am so pissed at myself.
This is why JS needs a good IDE to capture silly mistakes like this. Oh boy, do I miss my flash builder.....
BenFousek
There are many good editors with real time linting. I like Sublime Text - Download with SublimeLinter.
Also tasking running with Grunt: The JavaScript Task Runner
Esri has the .jshintrc (linting rules) file they use here jsapi-resources/jshint at master · Esri/jsapi-resources · GitHub
LefterisKoumis
Thanks. I downloaded and use webstorm. I followed instructions including uploading esrijs typescript library, but still didn't catch the case error of the script posted above.
