queryTask.execute Fails
4226
12
04-27-2018 09:06 AM
JamesCrandall
I'm getting a ReferenceError "results is not defined" on the queryTask.execute:
   //first, check to see if a workplan boundary exists
    if (this.workplanId) {
     var queryUrl = "https://somewebsite/someagssite/rest/services/folder/servicename/FeatureServer/0"
     var queryTask = new QueryTask(queryUrl);
     var query = new Query();
     query.returnGeometry = true;
     query.where = "workplanId ='" + this.workplanId + "'";
     debugger;
     queryTask.execute(query).then(function (results) {
         this.workplanCheckValue = results.features.length;
    console.log("workplanCheck value is: ", this.workplanCheckValue)
I need to set this.workplanCheckValue to the number of features returned from the queryTask.
Any assistance appreciated!
Tags (1)
RobertScheitlin__GISP
James,
   I tend to do my queries like this:
////first, check to see if a workplan boundary exists
                var queryUrl = "https://somesite/rest/services/myservice/FeatureServer/0";
                query.outFields = ['*']
                debugger;
                queryTask.execute(query, lang.hitch(this, function (result) {
                    debugger;
                    this.workplanCheckValue = result.features.length;
            console.log("workplanCheck value is: ", this.workplanCheckValue)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
James,
  Looks like a scope issue again. When you are inside a function that does not use lang.hitch or a closure then "this" has a different scope then outside the function.
JamesCrandall
I'm struggling on this whole concept for some reason.  It's just not registering how to apply and where -- my failed attempt:
queryTask.execute(query).then(lang.hitch(function (result) {
James,
   OK maybe I can help explain. Anytime you have some code that has a function that returns something that means it returns a different scope and thus has to be hitched to the current scope.
                queryTask.execute(query).then(lang.hitch(this, function (result) {
Your where missing the "this" that you were wanting to hitch to.
JamesCrandall
Now it leads me to a "TypeError: g.join is not a function"?  Something new. <-- this appears to be because my query.outFields not correctly set as an array.
However, I'm still getting the same error on my original code:
                debugger;
                    debugger;
            console.log("workplanCheck value is: ", this.workplanCheckValue)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Thanks again for your explanation!
Is that error coming from the function above?...
JamesCrandall
Sorry -- I was too slow.  I updated my last reply.  That other error was due to
JamesCrandall
This is what I see on result when in debug:
James,
                debugger;
                    debugger;
JamesCrandall
Oh actually, that does work.  My fault (again).
