QueryTask and Zoom to Result
8629
11
02-18-2013 05:47 AM
MJWaldstein
I am looking to see if anyone knows how I can have both a queryTask function and have the map zoom to the result automatically after the search button is clicked. I am stuck on how to create the zoom function, as my search works.
Below is the code i have for the search ability:
var watershed_areas = new esri.layers.ArcGISDynamicMapServiceLayer("http://54.245..................");
map.addLayers(watershed_areas);
findTask = new esri.tasks.FindTask("http://54.245...............");
    findParams = new esri.tasks.FindParameters();
    findParams.returnGeometry = true;
    findParams.layerIds = [0];
    findParams.searchFields = ["NWWTRSHDCD", "WTRSHDD"];
function execute(searchText) {
    findParams.searchText = searchText;
    findTask.execute(findParams, showResults);
   function showResults(results) {
    var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 1), new dojo.Color([255, 0, 0, 1]));
    map.graphics.clear();
    var dataForGrid = [];
    dojo.forEach(results, function(result) {
     var graphic = result.feature;
     dataForGrid.push([result.layerName, result.foundFieldName, result.value]);
     switch (graphic.geometry.type) {
      case "point":
       graphic.setSymbol(markerSymbol);
       break;
      case "polyline":
       graphic.setSymbol(lineSymbol);
       break;
      case "polygon":
       graphic.setSymbol(polygonSymbol);
       break;
     map.graphics.add(graphic);
    var data = {
     items : dataForGrid
    var store = new dojo.data.ItemFileReadStore({
     data : data
    grid.setStore(store);
If anyone could lend any assistance, i would greatly appreciate it.
Margaret
WillHughes1
Thanks Ken.
I just tried using the centerAndZoom method and it worked perfectly.
map.centerAndZoom(resultFeatures[0].geometry, .01);
Will
KenBuja
MVP Esteemed Contributor
Thanks Ken.
Will
You should check what happens when you try this multiple times to see if it continues to zoom in.
And when you find posts useful, made good use of the "This post was helpful" up-arrow 🙂
