Query Info without Map
951
02-01-2011 02:30 AM
RohitGarg
HI,
Please help me regarding below code. I want to display Query Info without Map. I copied this code from js sample code and i changed queryTask url and outFields name. But this is not working.. why? Please guide me.
RG
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <title>Query Info without Map</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.1/js/dojo/dijit/themes/claro/claro.css">
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.1"></script>
    <script type="text/javascript" language="Javascript">
      dojo.require("esri.tasks.query");
      dojo.require("esri.map");
      var queryTask, query;
      function init() {
        //build query
        queryTask = new esri.tasks.QueryTask("http://localhost:8399/arcgis/rest/services/future_india/MapServer/6");
        //dojo.connect(queryTask, "onComplete", showResults);
        //build query filter
        query = new esri.tasks.Query();
        query.returnGeometry = false;
  query.outFields = ["Lat", "Longs", "LocAddress"];
      function execute(stateName) {
        query.text = stateName;
        queryTask.execute(query,showResults);
      function showResults(results) {
   alert("showResults");
        var s = "";
        for (var i=0, il=results.features.length; i<il; i++) {
          var featureAttributes = results.features.attributes;
          for (att in featureAttributes) {
            s = s + "<b>" + att + ":</b>  " + featureAttributes[att] + "<br />";
        dojo.byId("info").innerHTML = s;
     dojo.addOnLoad(init);
    </script>
  </head>
  <body>
   name : <input type="text" id="stateName" value="Bhiwandi" />
    <input type="button" value="Get Details" onclick="execute(dojo.byId('stateName').value);" />
    <br />
    <br />
    <div id="info" style="padding:5px; margin:5px; background-color:#eee;">
    </div>
  </body>
</html>
HemingZhu
HI,
RG
<html>
  <head>
      function init() {
        //build query
        var s = "";
    </script>
  </head>
  <body>
    <br />
    <br />
    </div>
  </body>
</html>
I looked into your code. One line caught my attention: query.text = stateName; text is property shorthanded for a where clause using "like". The field used is the display field defined in the map document. please check your layer in Services Directory to see if your display field is the state field. I recommend you use query.where in stead of query.text (put your state in your outfields) and try again. you alos might put a error function callback in your queryTask.execute for debug purpose.
