Query geometry issue
2767
06-14-2016 12:24 PM
EvelynHernandez
I am trying to get the results from a FeatureLayer when the user clicks on the map.
My geometry is an map.MapPoint that i pass to the following function.
I tried to make a rectangle for making a polygon to add more range to the results but for some reasonim getting an error performing the query
function factigis_findDireccion(geometry,callback){
  var rectangulo = new esri.geometry.Polygon;
  rectangulo.addRing(crearRectangulo(geometry,1));
  console.log("my point",rectangulo);
  var qTaskInterruptions = new esri.tasks.QueryTask(layers.read_direcciones());
  var qInterruptions = new esri.tasks.Query();
  qInterruptions.returnGeometry = true;
  qInterruptions.outFields=["id_direccion","nombre_calle","numero"];
  qInterruptions.geometry = rectangulo ;
  qInterruptions.spatialRelationship = esri.tasks.Query.SPATIAL_REL_CONTAINS;
  qTaskInterruptions.execute(qInterruptions, (featureSet)=>{
    console.log("Find",featureSet);
    callback(featureSet.features);
  }, (Errorq)=>{
    console.log(Errorq,"Error doing interruptions nis by extent");
      return 0;
function crearRectangulo(mapPoint,delta){
  var arrayOfPoints = new Array();
  arrayOfPoints[0] = new esri.geometry.Point(mapPoint.x-delta,mapPoint.y-delta,mapPoint.spatialReference);
  arrayOfPoints[1] = new esri.geometry.Point(mapPoint.x-delta,mapPoint.y+delta,mapPoint.spatialReference);
  arrayOfPoints[2] = new esri.geometry.Point(mapPoint.x+delta,mapPoint.y+delta,mapPoint.spatialReference);
  arrayOfPoints[3] = new esri.geometry.Point(mapPoint.x+delta,mapPoint.y-delta,mapPoint.spatialReference);
  arrayOfPoints[4] = new esri.geometry.Point(mapPoint.x-delta,mapPoint.y-delta,mapPoint.spatialReference);
  return arrayOfPoints;
What im missing? thanks for ur help
EvelynHernandez
I found my issue, i had to make a polygon like this
  var rectangle = new esri.geometry.Polygon(new esri.SpatialReference(geometry.spatialReference));
  rectangulo.addRing([ [geometry.x-1,geometry.y-1],[geometry.x-1,geometry.y+1],[geometry.x+1,geometry.y+1],[geometry.x+1,geometry.y-1],[geometry.x-1,geometry.y-1] ]);
EvelynHernandez
