query Date Range syntax
5044
9
04-03-2017 12:04 PM
jaykapalczynski
Honored Contributor
Wondering if anyone can help with the syntax to query a date range?
query.where = "County_Nam = '" + (dom.byId("CountyName").value) + "' AND Squad = '" + (dom.byId("Squad").value) + "' ";
query.where = "County_Nam = '" + (dom.byId("CountyName").value) + "' AND Squad = '" + (dom.byId("Squad").value) + "' AND DateIncident = '" + (dom.byId("StartDate").value) + "' BETWEEN DateIncident = '" + (dom.byId("EndDate").value) + "' ";
2 Solutions
RobertScheitlin__GISP
And here is how I do most of mine:
query.where = "DateIncident BETWEEN timestamp '" + dom.byId("StartDate").value + "' AND timestamp '" + dom.byId("EndDate").value + "'"‍‍‍‍
@RobertKirkwood GETDATE() is a SQL server function if you want the date from JS code then it would look like this:
query.where = "'" + new Date().toJSON().slice(0,10).replace(/-/g,'/') + "' >= EXPIRATION_DATE";
The current date will look like "2022/06/15" based on the JS code above
Jay,
  What is the underlying data database type (SQL Server, Shapefile, FGDB, Oracle, AGOL)?
jaykapalczynski
Honored Contributor
SQL Server...This query works fine....just need the Date Range
Drew
We use MS SQL Server and we query our dates like so..
SAMPLE
query.where = "CreatedDateTime >= '2017/03/27 00:00:00 AM' AND CreatedDateTime <= '2017/04/03 11:59:59 PM'"
Sometimes its easier to test these things on the REST Endpoint too..
Drew
jaykapalczynski
Honored Contributor
Thank Andrew....your solution worked fine...
RobertKirkwood
How would i query value less than todays date? i was trying something like
query.where = GETDATE() >= "EXPIRATION_DATE"
But this is not working. Any thoughts?
RobertKirkwood
that worked perfectly! Thank you!
jaykapalczynski
Honored Contributor
Had to add two )  after value for start and end date but worked great
