Query after applyEdits() doesn't contain all new features
3197
8
06-10-2018 05:20 AM
MichaelLodes2
Hello all,
directly after creating and updating my hosted Featurelayer with applyEdits(), I would like to get the whole updated Featurelayer by a Query.
My code below does this task chain almost correctly, but sometimes it doesn't get all changes. I guess the db update by applyEdits() was not ready yet before quering it. Why? I use then() between the functions, so I thougt one function is executed when the function before has done everything correctly?
lyr.applyEdits({
     addFeatures: createFeatArr
    }).then(
        lyr.applyEdits({
         updateFeatures: updateFeatArr
        })).then(getFeatureIds(lyr));
getFeatureIds(lyr):
function getFeatureIds(lyr){
    var query = new Query();
    query.where = "1=1";
    query.outFields = ["MYSQLID", "FID"];
    var featuresArray = new Array();
    var arr = new Array();
    lyr.queryFeatures(query).then(function(results){
        results.features.forEach(function(item){
            featuresArray.push(item.attributes);
        for (var prop in featuresArray) {
                arr[featuresArray[prop].FID] =  featuresArray[prop].MYSQLID.toString();
        console.log("arr: " + arr);
Someone can help me?
Kind Regards
Michael
MichaelLodes2
I talked to esri support, they provided the solution for me. There have to be return commands when chaining promises. Like:
  .then(function(results) {
    results.features.forEach(function(item) {
  //adding features
    return lyr.applyEdits({
  //then updating features
  //and then quering featurelayer
MichaelLodes2
Nobody out there?
MichaelLodes2
Robert Scheitlin, GISP‌ Do you know an answer?
RobertScheitlin__GISP
Michael,
   No I don't. I would think the same as you that after the deferred is returned that the data should be query-able.
MichaelLodes2
After doing different tests I guess that the Promise returned by adding a feature with applyEdits(), is set too early to the "OK" status. Is this a bug?
I would report it to esri tech support and see if they can reproduce.
MichaelLodes2
  //adding features
MichaelVolz
Esteemed Contributor
Are you working with versioned SDE data?  Maybe the A and D table records are not available unless you can compress the database so the A and D records are moved to the default version of the SDE database.  Just a theory that you might try testing.
MichaelLodes2
I don't know "versionded SDE data" and "A and D table records". I am working with ArcGIS Online "Feature Layer (hosted)".
Thank you for your answer, Michael.
