Query a layer with multiple search criterias
10560
28
04-09-2014 08:05 PM
kiranbodhasrungi
hi,
i have a requirement in my project where i have to query the layer with the help of multiple search fields.How can i achieve this?
till now i have been doing it like this:
findParams.layerIds = [1];
findParams.searchFields = ["STREET_NAME", "STREET_NUMBER"];
findTask.execute(findParams, showResults);
I have  a single text box and i query the map with the help street name OR number.How can i combine both(similar to AND) to filter results?
thanks in advance.
keran.
MayJeff
Can you post the entire code in JSFiddle? Thanks.
kiranbodhasrungi
let me know if need the complete source code i can share it with you,i never used jsfiddle.
MayJeff
That will be great if you can post your complete source code.  Thanks for your time.
kiranbodhasrungi
i have attached the complete code.this is a simple eclipse web applicaiton,taket he web contents and ingore the rest.
Let me know if you have any issues.
MayJeff
Thank you for posting your code.  I run your index.html but no result return.  Am I missing something?
kiranbodhasrungi
What are you trying to do?what is your requirement?
MayJeff
I try to find a sample query able to search subdivision, city, parcel by address & parcel id when using enter information in the text box. Then return results in datagrid.  I only find sample using Find task but not using query Task. Besides that, would like to have select option for city so able to select and zoom to the city boundary.
Thanks.
kiranbodhasrungi
Here is the code to query a layer:
function init() {
  center = [-72.65065, 41.56232];
        zoom = 11;
        map = new esri.Map("map", {
          basemap: "topo",
         // center: center,
          zoom: zoom
  var dynamicMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer(
  "http://12.132.106.112:6080/arcgis/rest/services/MidParcelFabric/MapServer");
  map.addLayer(dynamicMapServiceLayer);
  queryTask = new esri.tasks.QueryTask(
  "http://12.132.106.112:6080/arcgis/rest/services/MidParcelFabric/MapServer/1");
  query = new esri.tasks.Query();
  query.returnGeometry = true;
  query.outFields = [ "OLD_MBL_1", "MAPLOT_1" , "MAP_1", "LOT_1", "CAMAACCT_1", "pid", "PROPERTY_LOCATIO", "STREET_NUMBER", "STREET_NAME" ,"UNIT__", "GRANTEE", "CO_GRANTEE_S_NAM", "Shape_Length", "Shape_Area" ];
  symbol = new esri.symbol.SimpleFillSymbol();
  symbol.style = esri.symbol.SimpleFillSymbol.STYLE_SOLID;
  symbol.color = new dojo.Color([98, 194, 204, 0.5]);
  dojo.addOnLoad(init);
  function executeQueryTask(streetName,streetNumber,ownerName,maplot,lot,unit,accountID,pid) {
  var queryString="";
  queryString+= "STREET_NAME" + " like '%" + streetName +"%'" ;
  queryString+= " OR " + "GRANTEE" + " like '%" + streetName +"%'" ;
  //queryString+= " OR " + "pid" + " = " + streetName ;
  console.log(queryString);
  query.where = queryString;
  queryTask.execute(query, showResults);
Call executeQuery() upon click or a search button or enter button,pass required parameters.
Pass the city value also to this function.
If you want a dojo datagrid instead of html table use the new.html in the code that i have given you.
Let me know if this solves your problem.
MayJeff
Thank you for your time.  I will work on it and let you know.
