Proxy access to tiles{s}.arcgis.com
2326
06-28-2019 12:18 AM
AndrewSander
I have a requirement to secure some tilelayers via the proxy.  The issue is that for standard builds of tiles from a local machine from ArcGIS PRO pushed to ArcGIS Online utilise the service endpoint of
https://tiles.arcgis.com/tiles/<id here>/arcgis/rest/services/<layer name here>/MapServer
Builds from ArcMap seem to cache the tiles across subdomains:
https://tiles{s}.arcgis.com/tiles/<id here>/arcgis/rest/services/<layer name here>/MapServer where {s} = 1,2,3,4
Whilst i understand one answer is to always use PRO, how can tiled web services built from ArcMap be secured utilising the proxy?
Thanks
RobertScheitlin__GISP
Andrew,
   You just add https://*.arcgis.com to your proxy.config
AndrewSander
Thanks Robert,
Sorry, forgot to mention the proxy.config has several entries for accessing other client's environments, so the wildcard option won't work for us in this case.
Andrew
Andrew,
This statement make no sense to me. Why would a wildcard for esri arcgis.com or arcgis.com/tiles not work for you?
