property color of SimpleFillSymbol does not work
2896
6
01-19-2018 08:29 AM
JoséTorres
Hi.
I have problem with the color property of SimpleFillSymbol in some polygons it works and in others not, what can you be? shipping part of the code.
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title></title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.6/esri/css/main.css">
<script src="https://js.arcgis.com/4.6/"></script>
<script src="script/regiones.js"></script>
<script>
require([
"esri/Map",
"esri/views/SceneView",
"esri/geometry/Polygon",
"esri/symbols/SimpleFillSymbol",
"dojo/dom",
"dojo/domReady!"
], function(Map, SceneView, Polygon, SimpleFillSymbol) {
var map = new Map({
basemap: "osm",
ground: "world-elevation"
var view = new SceneView({
container: "viewDiv",
map: map
center: [-71.650,-35.400]
var ringsRegiones = [
coordReg["arica"]
var polygonRegiones = new Polygon({
rings: ringsRegiones
var fillSymbolRegiones = new SimpleFillSymbol({
color: [227, 139, 79, 0.5],
outline: {
color: [0, 255, 197],
width: 2
var polygonGraphicRegiones = new Graphic({
geometry: polygonRegiones,
symbol: fillSymbolRegiones
view.graphics.add(polygonGraphicRegiones);
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
RobertScheitlin__GISP
Jose,
   Your point order in your polygon ring needs to go clockwise, your currently is counter-clockwise with is the issue:
So I just reversed the array and it worked fine (line 45).
<!DOCTYPE html>
<html>
<head>
  <title></title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
      "esri/Map",
      "esri/Graphic",
      "dojo/dom",
      "dojo/domReady!"
    ], function(Map, SceneView, Polygon, SimpleFillSymbol, Graphic) {
      var map = new Map({
        basemap: "osm",
        map: map,
        center: [-71.650, -35.400]
        coordReg["arica"].reverse()
        outline: {
          width: 2
  </script>
</head>
<body>
</body>
</html>
Jose,
  I don’t see anything wrong in your code you posted so that leads be to believe that ther must be something wrong with the geometry of those polygons, unless it is the case where you are querying a map service and have reached the max records for that service.
JoséTorres
Hi, thanks for your answer, try the polygon points in http://geojson.io and they are drawn well and the color of the interior appears perfect, but in my app only the color of the border appears.
Attached picture with the explained.
Jose,
   Can you provide your regiones.js for testing?
JoséTorres
Hello Robert, thank you for responding, I attached the js with the points of the regions.
Thanks again.
Jose,
<!DOCTYPE html>
<html>
<head>
  <title></title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
      "esri/Map",
      "esri/Graphic",
      "dojo/dom",
      "dojo/domReady!"
      var map = new Map({
        basemap: "osm",
        map: map,
        outline: {
          width: 2
  </script>
</head>
<body>
</body>
</html>
JoséTorres
Thank you very much Robet for your explanation, it works perfect
