Programmatically adding legnedDijit to the contentPane
1750
01-23-2014 01:05 AM
GaneshSolai_Sambandam
HI Guys
I have programmatically created a function to add Accordion Container with few child contentpane. When I try to add legendsDijit to the first contentPane, I get an error from the application saying legendDijit is null or not an object.
can anyone look into this. please.
//Add the legend to the application - the legend will be
//added to the left panel of the application.
function addLegend(layerInfo) {
    var legendTb = new dijit.form.ToggleButton({
        showLabel: true,
        label: i18n.tools.legend.label,
        title: i18n.tools.legend.title,
        checked: true,
        iconClass: 'esriLegendIcon',
    }, dojo.create('div'));
    dojo.byId('webmap-toolbar-left').appendChild(legendTb.domNode);
    dojo.connect(legendTb, 'onClick', function () {
        navigateStack('legendPanel');
   // var aContainer = new dijit.layout.AccordionContainer({style:"height: 300px"}, "legendPanel");
       var aContainer = new dijit.layout.AccordionContainer({id: "legendPanel1", style: "height:100%; width:100%"}, dojo.create('div'));
          var legendDijit = new esri.dijit.Legend({
        map: map,
        layerInfos: layerInfo
   //legendDijit.startup();
  /* var layers = new dijit.layout.ContentPane({title:"Layers"});
   layers.set('content', legendDijit.domNode);
   aContainer.domNode.appendChild(layers);*/
      aContainer.addChild(new dijit.layout.ContentPane({
            title: "Layers",
            region: 'center',
            selected: true,
           content: "hi",
            title:"BaseMapGallery",
            content:"Hi how are you?"
            title:"Print",
            content:"Hello im fine.. thnx"
        //dojo.byId('aLayers').appendChild(legendDijit.domNode);
        aContainer.startup();
        /*  var legendDijit = new esri.dijit.Legend({
        map: map,
   // dijit.byId('aLayers').appendChild(legendDijit.domNode)
   // legendDijit.startup();
    var legendCp = new dijit.layout.ContentPane({
        selected: true,
        region: 'center',
         //dojo.byId('legendPanel').appendChild(aContainer.domNode);
    dijit.byId('stackContainer').addChild(legendCp);
   dojo.addClass(dojo.byId('legendPanel'), 'panel_content');
    /*var legendDijit = new esri.dijit.Legend({
        map: map,
    dojo.byId('legendPanel').appendChild(legendDijit.domNode);*/
    if (dojo.isIE === 8) {
        setTimeout(function () {
         //  aContainer.startup();
        }, 100);
    } else {
RobertoPepato
HI Guys
        showLabel: true,
        checked: true,
        map: map,
            title: "Layers",
            region: 'center',
            selected: true,
           content: "hi",
            title:"Print",
        map: map,
        selected: true,
        region: 'center',
        map: map,
        }, 100);
    } else {
Are you requiring the desired dijit on your code?
dojo.require("esri.dijit.Legend");
HI Pepa
I already included the necessary required resources dojo.require("esri.dijit.Legend");
If I comment out my accordionpane variable in the code, my legend dijit works. I wanted to add the legend inside the first child of the accordionpane and the problem persist here.
regards
Ganesh
RobertoPepato
HI Pepa
regards
Ganesh
Could your please post your full page code so I can try to figure out what's happening?
