Programmatically activate infotemplate window? (Urgent)
1347
11-26-2013 07:35 PM
EdwardSohn1
Is there way to manually activate from code (Javascript) the infotemplate window for a given feature?
What is desired is for row to be selected from datagrid and the corresponding feature to be zoomed to on the map and at the same time the info window for that feature to be activated (shown) without user click action.
ManojrajTeli
Hello Edward,
You might find this example helpful.
https://developers.arcgis.com/en/javascript/jssamples/fl_zoomgrid.html
http://storymaps.esri.com/home/
http://mediamaps.esri.com/nfl-hof/
There is one ready to use example on net that can suite your need.
Manojraj
EdwardSohn1
Resolved:
using http://forums.arcgis.com/threads/547...Features+empty
adding:
map.infoWindow.hide();
map.infoWindow.clearFeatures();
before setFeatures might have done it...
