Problems using Angular with JS API: No overload matches this call.
9007
04-30-2021 08:25 AM
Xuyang-Han
Hello All,
I am using Angular Typescript with ArcGIS API. Once I copied some sample codes from the documents, there are some bugs on it. I pasted the error message and my codes below. I marked the bugs in red colour.
error:
Overload 1 of 2, '(properties?: GraphicProperties): Graphic', gave the following error.
Type '{ type: string; color: string; }' is not assignable to type 'SymbolProperties'.
Object literal may only specify known properties, and 'type' does not exist in type 'SymbolProperties'.
Overload 2 of 2, '(properties?: GraphicProperties): Graphic', gave the following error.
Object literal may only specify known properties, and 'type' does not exist in type 'SymbolProperties'.ts(2769)
interfaces.d.ts(5819, 5): The expected type comes from property 'symbol' which is declared here on type 'GraphicProperties'
My Code:
import { ComponentOnInitViewChildElementRef } from '@angular/core';
import EsriMap from "@arcgis/core/Map";
import MapView from "@arcgis/core/views/MapView";
import Graphic from "@arcgis/core/Graphic";
import GraphicsLayer from "@arcgis/core/layers/GraphicsLayer";
import Home from "@arcgis/core/widgets/Home";
import Track from "@arcgis/core/widgets/Track";
@Component({
  selector'app-map',
  templateUrl'./map.component.html',
  styleUrls: ['./map.component.css']
export class MapComponent implements OnInit {
  mapEsriMap;
  viewMapView;
  constructor() { }
  ngOnInit() {
    // Add Based Map
    const map = new EsriMap({
      basemap"streets-vector"
    // add initial view, position, and zoom
    const view = new MapView({
      mapmap,
      container"viewDiv",
      center: [-79.50293843.767854],
      zoom12
    // adds the home widget to the top left corner of the MapView
    var homeWidget = new Home({
      viewview
    view.ui.add(homeWidget"top-left");
    const track = new Track({
      viewview,
      graphicnew Graphic({
        symbol: {
          type"simple-marker",
          // size: "12px",
          color"green",
          // outline: {
          //   color: "#efefef",
          //   width: "1.5px"
      useHeadingEnabledfalse
    view.ui.add(track"top-left");
    // draw a point on a layer
    const point = { //Create a point
      type"point",
      longitude: -79.502938,
      latitude43.767854
    const simpleMarkerSymbol = {
      color: [22611940],  // Orange
      outline: {
        color: [255255255], // White
        width1
    const graphicsLayer = new GraphicsLayer();
    map.add(graphicsLayer);
    const pointGraphic = new Graphic({
      geometrypoint,
      symbolsimpleMarkerSymbol
    graphicsLayer.add(pointGraphic);
VictorBerchet
I had the same problem using the API.
It is due to the TypeScript types not matching the actual signature of the method.
I solve it the ugly way by writing:
new Graphic({ symbol: this.txtSymbol as any });
The less ugly way would be to create a Symbol instance instance of using an object literal with a type.
It would be interesting to hear from the API team if that is only a problem with the typings or if long term the API will drop support for object literals.
ReneRubalcava
Esri Frequent Contributor
TypeScript doesn't like autocasting used in constructors. You can make it work by specifying new SimpleMarkerSymbol() and new Point() in your code.
VictorBerchet
Xuyang-Han
Thank you. It works!
