Problems setting up StreetView widget for Sample Viewer ESRI
905
12-03-2012 02:25 AM
JoseSanchez
Hi all
I downloaded the StreetView widget for Sample Viewer ESRI
http://www.arcgis.com/home/item.html?id=2ba0b738ae2c444f88c69ccd0d37c3f4
but I do not understand how to set it up reading the ReadMe.txt
for example
1) Copy image in folder icons\icon\i_streetView.png in folder js\com\esri\solutions\jsviewer\assets\images\icons
where is the folder js\com\esri\solutions\jsviewer\assets\images\icons?
Thanks
JeffPace
Hi all
for example
Thanks
The Javascript Sample Viewer was abandoned by ESRI years ago.  A few of us continue to maintain our own versions.
If you are using the correct sample viewer, that folder structure should exist.
