Problem with visibility of layers and popup
4577
5
07-01-2015 03:15 AM
EduardoDomínguez
Hi all,
I am having a problem because I cannot use the same layer for popup and visibility. What I want is when a layer is off, this layer has not popup window till is in on again. But if I put the same layer for both an error emerges like layer is not a function.
Here goes the code, TAKE INTO ACCOUNT THAT layerA = layerB. Thanks in advance:
<script src="http://js.arcgis.com/3.13/"></script>
  <script>
   var map, identifyTask, findTask, findParams, identifyParams;
    require([
      "esri/map",
      "esri/geometry/Extent",
      "esri/layers/FeatureLayer",
      "esri/dijit/Legend",
      "esri/layers/ArcGISDynamicMapServiceLayer",
      "esri/layers/ImageParameters",
      "esri/InfoTemplate",
      "esri/dijit/BasemapGallery",
      "esri/dijit/Scalebar",
      "esri/symbols/SimpleFillSymbol",
       "esri/symbols/SimpleLineSymbol",
       "esri/symbols/SimpleMarkerSymbol",
       "esri/tasks/IdentifyTask",
       "esri/tasks/IdentifyParameters",
       "esri/tasks/FindParameters",
       "esri/dijit/Popup",
       "esri/dijit/Measurement",
        "esri/toolbars/draw",
        "esri/graphic",
        "dojo/on",
        "esri/tasks/query",
        "esri/layers/LayerDrawingOptions",
        "dojo/_base/Color",
        "dojo/dom-construct",
        "dojo/dom",
        "dojo/query",
        "esri/tasks/FindTask",
        "dojo/_base/array",
        "dojo/_base/connect",
        "dojox/grid/DataGrid",
        "dojo/data/ItemFileReadStore",
        "dojo/_base/array", "dojo/parser",
        "dijit/layout/BorderContainer",
        "dijit/layout/ContentPane",
        "dijit/layout/AccordionContainer",
        "dijit/form/ComboBox",
        "dojo/domReady!"
    ], function(
      Map,
      Extent,
      FeatureLayer,
      Legend,
      ArcGISDynamicMapServiceLayer,
      ImageParameters,
      InfoTemplate,
      BasemapGallery,
      Scalebar,
      SimpleFillSymbol,
      SimpleLineSymbol,
      SimpleMarkerSymbol,
      IdentifyTask,
      IdentifyParameters,
      FindParameters,
      Popup,
      Measurement,
      Draw,
      Graphic,
      on,
      Query,
      LayerDrawingOptions,
      Color,
      domConstruct,
      dom,
      query,
      FindTask,
      arrayUtils,
      connect,
      DataGrid,
      ItemFileReadStore,
      arrayUtils,
      parser
      parser.parse();
var extentinitial= new Extent({
"xmin":5533768.561124517,
"ymin":2910407.85970325,
"xmax":5969153.874236671,
"ymax":3018948.4398681484,
"spatialReference":{"wkid":102100,"latestWkid":2932}
var popup = new Popup({
          fillSymbol: new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
            new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
              new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.25]))
        }, domConstruct.create("div"));
      map = new Map("map", {
        basemap:"topo",
        extent: extentinitial,
        zoom: 9
var layerA = new ArcGISDynamicMapServiceLayer("http://XXX", {
var basemapGallery = new BasemapGallery({
        showArcGISBasemaps: true,
        map: map
        }, "basemapGallery");
        basemapGallery.startup();
        basemapGallery.on("error", function(msg) {
        console.log("basemap gallery error:  ", msg);
      //add the legend
     var legend = new Legend({
        map: map,
        }, "legendDiv");
        legend.refresh([{layer:layerA, title:'LEGEND'}]);
        legend.startup();
map.addLayer(layerA);
      var visibleLayerIds = []
          on(dom.byId("layer0CheckBox"), "change", updateLayerVisibility);
          on(dom.byId("layer1CheckBox"), "change", updateLayerVisibility);
          on(dom.byId("layer2CheckBox"), "change", updateLayerVisibility);
          on(dom.byId("layer3CheckBox"), "change", updateLayerVisibility);
          on(dom.byId("layer4CheckBox"), "change", updateLayerVisibility);
          on(dom.byId("layer5CheckBox"), "change", updateLayerVisibility);
          on(dom.byId("layer6CheckBox"), "change", updateLayerVisibility);
          on(dom.byId("layer7CheckBox"), "change", updateLayerVisibility);
          on(dom.byId("layer8CheckBox"), "change", updateLayerVisibility);
          on(dom.byId("layer9CheckBox"), "change", updateLayerVisibility);
          on(dom.byId("layer10CheckBox"), "change", updateLayerVisibility);
          on(dom.byId("layer11CheckBox"), "change", updateLayerVisibility);
          on(dom.byId("layer12CheckBox"), "change", updateLayerVisibility);
          on(dom.byId("layer13CheckBox"), "change", updateLayerVisibility);
          on(dom.byId("layer14CheckBox"), "change", updateLayerVisibility);
          on(dom.byId("layer15CheckBox"), "change", updateLayerVisibility);
          on(dom.byId("layer16CheckBox"), "change", updateLayerVisibility);
          on(dom.byId("layer17CheckBox"), "change", updateLayerVisibility);
          on(dom.byId("layer18CheckBox"), "change", updateLayerVisibility);
          on(dom.byId("layer19CheckBox"), "change", updateLayerVisibility);
          on(dom.byId("layer20CheckBox"), "change", updateLayerVisibility);
           on(dom.byId("layer21CheckBox"), "change", updateLayerVisibility);
          function updateLayerVisibility () {
            var inputs = query(".list_item");
            var inputCount = inputs.length;
            visibleLayerIds = [];
            for (var i = 0; i < inputCount; i++) {
              if (inputs.checked) {
                visibleLayerIds.push(inputs.value);
            if (visibleLayerIds.length === 0) {
              visibleLayerIds.push(21);
            layerA.setVisibleLayers(visibleLayerIds);
       map.on("load", mapReady);
       var imageParameters = new ImageParameters();
          imageParameters.layerIds = [0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21];
          imageParameters.layerOption = ImageParameters.LAYER_OPTION_SHOW;
        var layerB = "http://XXX";
        map.addLayer(new ArcGISDynamicMapServiceLayer(layerB,
          {"imageParameters": imageParameters, visible: false }));
          function mapReady () {
          mapClick = map.on("click", function(event){
            executeIdentifyTask(event);
          identifyTask = new IdentifyTask(layerB);
          identifyParams = new IdentifyParameters();
          identifyParams.tolerance = 3;
          identifyParams.returnGeometry = true;
          identifyParams.layerIds = [0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21];
          identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_VISIBLE;
          identifyParams.width = map.width;
          identifyParams.height = map.height;
        function executeIdentifyTask (event) {
          identifyParams.geometry = event.mapPoint;
          identifyParams.mapExtent = map.extent;
          var deferred = identifyTask
            .execute(identifyParams)
            .addCallback(function (response) {
              return arrayUtils.map(response, function (result) {
                var feature = result.feature;
                var layerName = result.layerName;
                feature.attributes.layerName = layerB;
                if (layerName === 'L1') {
                  var azTemplate = new InfoTemplate("L1");
                  feature.setInfoTemplate(azTemplate);
                else if (layerName === 'L2') {
                  var hyTemplate = new InfoTemplate(
                    "L2");
                  feature.setInfoTemplate(hyTemplate);
                else if (layerName === 'L3') {
                  var siTemplate = new InfoTemplate(
                    "L3");
                  feature.setInfoTemplate(siTemplate);
                else if (layerName === 'L4') {
                  var psTemplate = new InfoTemplate(
                    "L4");
                  feature.setInfoTemplate(psTemplate);
                 else if (layerName === 'L5') {
                  var daTemplate = new InfoTemplate(
                    "L5");
                  feature.setInfoTemplate(daTemplate);
                else if (layerName === 'L6') {
                  var slTemplate = new InfoTemplate(
                    "L6");
                  feature.setInfoTemplate(slTemplate);
                else if (layerName === 'L7') {
                  var tsTemplate = new InfoTemplate(
                    "L7");
                  feature.setInfoTemplate(tsTemplate);
                 else if (layerName === 'L8') {
                  var acoTemplate = new InfoTemplate(
                    "L8");
                  feature.setInfoTemplate(acoTemplate);
                 else if (layerName === 'L9') {
                  var ceTemplate = new InfoTemplate(
                    "L9");
                  feature.setInfoTemplate(ceTemplate);
                 else if (layerName === 'L10') {
                  var vrsTemplate = new InfoTemplate(
                    "L10");
                  feature.setInfoTemplate(vrsTemplate);
                  else if (layerName === 'L11') {
                  var rsTemplate = new InfoTemplate(
                    "L11");
                  feature.setInfoTemplate(rsTemplate);
                 else if (layerName === 'L12') {
                  var cuTemplate = new InfoTemplate(
                    "L12");
                  feature.setInfoTemplate(cuTemplate);
                 else if (layerName === 'L13') {
                  var rmTemplate = new InfoTemplate(
                    "L13");
                  feature.setInfoTemplate(rmTemplate);
                 else if (layerName === 'L14') {
                  var shTemplate = new InfoTemplate(
                    "L14");
                  feature.setInfoTemplate(shTemplate);
                else if (layerName === 'L15') {
                  var acTemplate = new InfoTemplate(
                    "L15");
                  feature.setInfoTemplate(acTemplate);
                else if (layerName === 'L16') {
                  var foTemplate = new InfoTemplate(
                    "L16");
                  feature.setInfoTemplate(foTemplate);
                  else if (layerName === 'L17') {
                  var geTemplate = new InfoTemplate(
                    "L17");
                  feature.setInfoTemplate(geTemplate);
                 else if (layerName === 'L18') {
                    "L18");
                 else if (layerName === 'L19') {
                  var pvTemplate = new InfoTemplate(
                    "L19");
                  feature.setInfoTemplate(pvTemplate);
                else if (layerName === 'L20') {
                  var lpTemplate = new InfoTemplate(
                    "L20");
                  feature.setInfoTemplate(lpTemplate);
                else if (layerName === 'L21') {
                    "L21");
                    else if (layerName === 'L22') {
                  var bsTemplate = new InfoTemplate(
                    "L22");
                  feature.setInfoTemplate(bsTemplate);
                return feature;
          map.infoWindow.setFeatures([deferred]);
          map.infoWindow.show(event.mapPoint);
       var scalebar = new Scalebar({
          map: map,
          scalebarUnit: "metric"
        function initt() {
        esri.config.defaults.io.proxyUrl = "/proxy/";
        esri.config.defaults.io.alwaysUseProxy = false;
        esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
        dojo.connect(map, 'onLoad', function(map) {
        var measurement = new Measurement({
          map: map
        }, dom.byId("measurementDiv"));
        measurement.startup();
        on(measurement, "tool-change", function(){
          mapClick.remove();
        on(measurement, "measure-end", function(){
          measurement.setTool("distance", false);
          measurement.setTool("area", false);
          measurement.setTool("location", false);
          mapReady();
           map.graphics.clear();
      dojo.ready(initt);
  </script>
RobertScheitlin__GISP
Eduardo,
   Your code is kind of hard to follow. But why do you not just add the layer once and set a PopupTemplate for that one layer, that way when the layer is turned off the popups will not function. You know you can have a PopupTemplate without using the identify task right? Here is a sample:
Popup | ArcGIS API for JavaScript
EduardoDomínguez
Thanks, but I think that a template is not the best thing because I need information of 21 layers.
Or is it also possible by using template? (I am a beginner with js so sorry for my code)
El 01/07/2015, a las 16:31, "Robert Scheitlin, GISP" <[email protected]> escribió:
GeoNet
reply from Robert Scheitlin, GISP in ArcGIS API for JavaScript - View the full discussion
Eduardo,
Reply to this message by replying to this email, or go to the message on GeoNet
Start a new discussion in ArcGIS API for JavaScript by email or at GeoNet
Following Problem with visibility of layers and popup in these streams: Inbox
This email was sent by GeoNet because you are a registered user.
You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences
Eduardo,
  You can have a template setup for all 21 of your layers of your Dynamic service. The sample I linked is just for one feature layer but the PopupTemplate can be applied to each sub layer of a ArcGISDynamicMapServiceLayer as well using the setInfoTemplates method.
ArcGISDynamicMapServiceLayer | API Reference | ArcGIS API for JavaScript | setInfoTemplates
Like this:
      var demographicsLayer = new ArcGISDynamicMapServiceLayer(demographicsLayerURL, demographicsLayerOptions);
      demographicsLayer.setInfoTemplates({
        1: { infoTemplate: _blockGroupInfoTemplate },
        2: { infoTemplate: _countyCensusInfoTemplate }
The above code snippet came from this sample:
Add two dynamic maps | ArcGIS API for JavaScript
EduardoDomínguez
Many thanks. So can it be used to create popup from a dynamic service layer with 21 layers??
El 1/7/2015, a las 17:33, Robert Scheitlin, GISP <[email protected]> escribió:
GeoNet
Eduardo,
Like this:
2:
Yes.
