problem with popup documentation
697
09-04-2013 07:42 AM
JeffPace
looks like the popup documentation is busted
there are no events
JonathanUihlein
Thanks for the heads up! Looks like the documentation is there, but hidden with styling.
In the meantime, if you want to see the specific Event Details, you can use a web-developer extension (such as firebug) and remove the class 'hidden' from the following two divs:
evtSwitchDetail, connectEventsDetail
You should be able to see the event details after doing this.
