Problem with polygon graphics in ImageBlender application
1331
11-12-2010 03:52 AM
PauPérez_Puigcerver
I'm using the application ImageBlender to make a HTML page to print, with the image returned by application.
The application works fine with points, polylines, and texts graphics, but not with polygons. When I draw a polygon whith any polygon symbol, the application doesn't return any image.
When I choose Default polygon symbol, the graphicList variable has this value (polygon with 3 points): FILLPOLYGON;0_0_0_0_0_0_0.25;302,190%406,205%378,291$FILLPOLYGON;0_0_0_0_0_0_0.25
And with Solid: FILLPOLYGON;255_0_0_255_255_0_0.5;322,137%469,182%309,281$FILLPOLYGON; 255_0_0_255_255_0_0.5
I don't undertand this part of variable: $FILLPOLYGON;255_0_0_255_255_0_0.5
Which format does the application use for polygons?
Does anybody know what happens?
PauPérez_Puigcerver
If I replace FILLPOLYGON with HOLLOWPOLYGON or DASHPOLYGON, it also works fine.
Pau Pérez
PauPérez_Puigcerver
Finally I have a solution.
The problem was the transparency parameter passed to the application.
In Default.aspx, the parameter was passed with point as decimal delimiter, and the application works with coma delimiter (at least on my server).
This is the solution:
var transPol = String(dojo.number.round(graphics.symbol._fill.a,2));
graphicSymbol += "_" + graphics.symbol._fill.r + "_" + graphics.symbol._fill.g + "_" + graphics.symbol._fill.b + "_" + transPol.replace(".",",");
//graphicSymbol += "_" + graphics.symbol._fill.r + "_" + graphics.symbol._fill.g + "_" + graphics.symbol._fill.b + "_" + graphics.symbol._fill.a;
Pau Pérez
gisscconsulting
Thanks for the input. This issue is resolved and there are more features added.
http://www.arcgis.com/home/item.html?id=81224fec1c3c47149b4d07c3c9b8027d
PauPérez_Puigcerver
Thanks for the new version. I will test it.
Regards.
Pau Pérez
