Problem with example
2108
7
10-20-2010 05:24 AM
DanielTuracek
Hi I would like to ask on something what make me sad for this day. I spent maybe 5 hours looking for reason why this code doesnt work.
Im newbie in Javascript for API ,so i dont know why it doenst work. I try use example code with my URL for my service and it doesnt work.
With normal example it works great.
Can anzbody help me?
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <meta http-equiv="X-UA-Compatible" content="IE=7" />
    <title>Create Map</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/1.6/js/dojo/dijit/themes/tundra/tundra.css">
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=1.6"></script>
    <script type="text/javascript">
        dojo.require("esri.map");
        function init() {
            var map = new esri.Map("map");
            var imageParameters = new esri.layers.ImageParameters();
            imageParameters.format = "JPEG";  //set the image type to JPEG, note default is PNG8.
            //Takes a URL to a non cached map service.
            var dynamicMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://serverapp:8399/arcgis/services/HranicaSR2/MapServer", { "opacity": 0.5, "imageParameters": imageParameters });
            map.addLayer(dynamicMapServiceLayer);
        dojo.addOnLoad(init);
    </script>
  </head>
  <body class="tundra">
    <div id="map" style="width:900px; height:600px; border:1px solid #000;"></div>
    Creates a map and adds an ArcGISDynamicMapServiceLayer.<br />
    Map navigation using mouse:
    <ul>
      <li>Drag to pan</li>
      <li>SHIFT + Click to recenter</li>
      <li>SHIFT + Drag to zoom in</li>
      <li>SHIFT + CTRL + Drag to zoom out</li>
      <li>Mouse Scroll Forward to zoom in</li>
      <li>Mouse Scroll Backward to zoom out</li>
      <li>Use Arrow keys to pan</li>
      <li>+ key to zoom in a level</li>
      <li>- key to zoom out a level</li>
      <li>Double Click to Center and Zoom in</li>
    </ul>
  </body>
</html>
nicogis
DanielTuracek
i give you know tomorow , because its our local test arcgis server, so i havent connection now.
There is probably problem with my service, i tried to get my service on display with more codes wich works fine for Arcgis example servers, but for my service i get just blank page.
I tried service for tiled map and dynamic too. i tried to import coordinate system from example files. but still nothing
thank you
and tomorow i will tell you more
DanielYim
First off, I want to mention that your code would've been easier to read and analyze with the forum's
 tags instead of what you used.
Anyway, one glaring problem that I see is that you're using the ArcGIS JS API version 1.6. This may be a deliberate choice of yours, but there is a much newer and better version out (v2.1). If you have mistakingly been using 1.6, then change
to
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.1"></script>
and also change the external CSS from
to
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.1/js/dojo/dijit/themes/claro/claro.css">
Other than that, I don't see why it shouldn't work. You should definitely look into ciava.at's suggestion, as I also think your use of custom imageParameters (set to JPEG) is why it's not rendering.
Good luck!
AxelSchaefer
You code is OK, your URL is wrong. You're not accessing the rest endpoint of your service.
Your URL is:
Should be something like:
http://serverapp:8399/arcgis/rest/services/HranicaSR2/MapServer
DanielTuracek
Ok
I tried everything but no result.
Its seems like our rest doesnt work right way, because i copy the URL links directly from service manager, and there is no any rest middle of URL.
So i dont know.
AxelSchaefer
javanse_jongense,
ArcGIS Server supports per default - and beside others - two standard interfaces for every service: SOAP and REST. While the Service Manager and all of the Web-ADF, as the ArcGIS Desktop apps, consume ArcGIS Server services over SOAP, the Web-API like JS, Silverlight, Flex consume the AGS Services over REST.
The difference between the URLs to the services is the rest part, as I have said before.
Please take a look at the documentation of the JS API: http://help.arcgis.com/en/webapi/javascript/arcgis/help/jshelp_start.htm#jshelp/ags_overview.htm
Especially take a look at your Services Directory at: http://serverapp:8399/arcgis/rest/ or any other service directory like The ArcGIS Online Services Directory.
Hope that helps.
DanielTuracek
Ok i Got it 🙂
Now its everything working perfectly.
I dont know where i made mistake but it seems to be OK now.
Shame on me...
Thanks for everybody.
I can start learning JAVASCRIPT API 🙂
