Problem while convrting mappoint in to screenpoint using Arcgis Javascript API
1459
06-09-2013 09:07 AM
HarshanandWankhede
0 down vote favorite
I am getting very strange problem when converting from Map point to screenpoint.
I am using following code.
var sp = esri.geometry.ScreenPoint(512, 151); mp = map.toMap(sp);
When we convert from ScreenPoint(512, 151) to Mappoint, I am getting following map coordinate. 338638.7275175141, 4404774.250335829
Now when I perform reverse conversion, i.e from same above Mappoint(338638.7275175141, 4404774.250335829) to ScreenPoint, I am getting very different screenpoints.i.e. (31563417740, -72455974). I guess now again I should get same screenpoint(512, 151). For this reverse conversion I am using following code. mp1 = new esri.geometry.Point(338638.7275175141, 4404774.250335829); sp1 = map.toScreen(mp1);
What I am getting very different screenpoint not (512,151)
VinayBansal
Have you tried by passing spatial reference to the point .... and then converting that point to screen point
new esri.geometry.Point(-118.15, 33.80, new esri.SpatialReference({ wkid: 4326 }));
Because from 3.3 if you are not passing the spatial reference, default 4326 is used.
