Problem for Advanced high quality print with secured service
2220
11-08-2013 07:43 AM
weeyeo
I keep getting error message ("Error executing print task") when try to print larger size map with secured services using sample here (http://resources.arcgis.com/en/help/main/10.1/index.html#/Tutorial_Advanced_high_quality_web_map_pri...)
If you entering your username & password then able to print larger map without any problem at all.
Does anyone able to print larger size map with secure services and modify their python script?
Thank you.
