Printing results in empty symbol in legend
8074
10
05-16-2017 12:32 PM
NaciDilekli
I am seeing a strange behavior with the print function. On the printed document the legend symbol is empty (while it is shown properly in some other legend tool) for this one feature service I have been using. I noticed this happens only if the fill color is assigned "No Color" in ArcMap. Otherwise, it renders it OK. It also shows it fine if I use a dynamic service, however, I don't want to use it as linear features are rendered horribly (aliasing I presume?) on the map. What might be causing this, is there a workaround? I tried both Esri's (https://utility.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%...) and my own print task. I am attaching an image of how it looks (The campus boundary is supposed to be a red empty polygon).
AndresCastillo
Hi Ross,
Can you please elaborate?
Do you mean that you followed these instructions?
https://enterprise.arcgis.com/en/server/10.7/create-web-apps/windows/tutorial-publish-additional-layouts-for-printing-with-arcgis-pro.htm
