Printing issue with graphics layer and legend
6563
16
05-11-2010 12:46 PM
JamesTanis
I am having some weird behavior with the print page.  First, I am using ESRI's street maps as my base layer then I have a graphics layer on top of along with a legend.  The problems that I am having are if I am zoomed out to the state level and launch the print page the base map is pu into four tiles down the page, while the graphics layer is centered in the page and not in the correct location and the legend does not show up (Picture 1).  Second, if I am zoomed into the a county or tract I have the same problem but this time there are less tiles for the base map and the legend shows up but with no background (Picture 2).  Fianlly, if you use firefox the graphics layer or the lengend never show up in the print page.  Any help would be greatly appreciated.
function clickheretoprint(divId, title, right, top, w, h) {
    if (right == null) right = 100;
    if (top == null) top = 25;
    if (w == null) w = 1000;
    if (h == null) h = 1000;
    if (title == null) title = "Print Screen";
    var disp_setting = "toolbar=yes,location=no,directories=yes,menubar=yes,";
    disp_setting += "scrollbars=yes,width=" + w + ", height=" + h + ", right=" + right + ", top=" + top;
    //get the html of the div
    var content_vlue = dojo.byId('mapDiv').innerHTML;
    //strip out the link tags else we'll link back to the mapper page
    content_vlue = content_vlue.replace(/<a/g, "<span");
    content_vlue = content_vlue.replace(/<\/a/g, "</span");
    var docprint = window.open("", "", disp_setting);
    docprint.document.open();
    docprint.document.write('<html><head><title>' + title + '</title>');
    docprint.document.write('<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=1.6"></script>');
    docprint.document.write('</head><body onLoad="self.print()"><left>');
    docprint.document.write('<div id="position" style="position:absolute;margin-left:50px;margin-top:50px;">');
    docprint.document.write(content_vlue);
    docprint.document.write('</left></body></html>');
    docprint.document.close();
    docprint.focus();
MikeMartin
Exploring the Map2PF also...
Curious about the new 2.1 and if you have any sample code written for this using the 2.1 you'd share? and did you use one namespace (pointing to 2.1) or two+ ?
thanks!
All I have is a button that fires the function above. Re. 2.1 namespace, my only references to the api are the script
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.1"></script> and the css
<style type="text/css"> @import "http://serverapi.arcgisonline.com/jsapi/arcgis/2.1/js/dojo/dijit/themes/tundra/tundra.css";
Hope that answers your question, I'm not an expert at this stuff by any means.
anwarawad
dear mmartin
would you plzzzz send me a code snipit showing the complete block of code involved with your function you posted  that works with 2.1v ??
ill be soooo thankful
am trying to print a map with charts on it , which are picture markers
i used the print function mentioned before in the thread but i only can se the graphics on the screen, but not on the printout paper
could you plzzz help ?? its urgent
regards to all
GlenRhea
text = document
print(text)
This doesn't work when you're creating the page dynamically. Still searching for a halfway decent (and simple) way to print using a js viewer.
Glen
Todd
For printing with JSAPI make sure you check out the Image Blender utility.
Regards,
Todd
anwarawad
hii
i want to creat a layout page and add the map to that layout with the graphics on it
that layout is printable ,, soo is the image blender is the best choice for that scenario ??
or can i do somethin else ???
thanx for replying
MikeMartin
dear mmartin
regards to all
The function itself is
[INDENT]function printscreen(text) {
[INDENT]text = document
print(text)
[/INDENT]}[/INDENT]
In the <body> I have
<button dojoType="dijit.form.Button" onClick="printscreen()">Print Map</button>
That's it. An example of a result is attached, showing a graphics layer, a dynamic layer, a tiled layer, and an info window.
Mike
anwarawad
hi
thanx alot for the help ,,
