Print/Write a map in a PDF document.
9351
11
12-20-2014 11:37 PM
El_BoukfaouiReda
Dear All,
I am working on reports related to tables and statistics.
I am conducting a search through dropdownlist selections and queries which is working just fine:
var selectQuery = new esri.tasks.Query();
selectQuery.where = "NAME_ENGLISH LIKE '" + evt.target.value + "'";
selectQuery.outFields = ["*"];
var upc_fi_selectQuery = new esri.tasks.Query();
upc_fi_selectQuery.spatialRelationship = selectQuery.SPATIAL_REL_CONTAINS;
AttFeatureLayer.selectFeatures(upc_fi_selectQuery, esri.layers.FeatureLayer.SELECTION_NEW, function (features)
// do this and that
After that I am running a script to write tables in a Windows document as follows (for instance):
var newWin =  window.open("");
newWin.document.write ("<label style='font-family: Trebuchet MS; font-weight:bold; font-size: 18px; color: #C0504D;'>Tourism Ecosystems Zone Details</label>");
newWin.document.write(Rep_T_tbTCA.outerHTML); // writing a table in a pdf document.
newWin.document.write ('<br></br>');
  newWin.document.write("<label style='font-family: Trebuchet MS; font-weight:bold; font-size: 18px; color: #C0504D; page-break-after: always'>Location of the the feature</label>");
Till now everything works just fine.
The map now is zoomed to the selected feature.
Now, I need to print the current extent of the map inside the pdf document:
HTML
<div id="map" class="map" align="justify"
  data-dojo-type="dijit/layout/ContentPane">
  </div>
Javascript
var mapd = document.createElement("div");
  mapd.id = "map_rep";
  mapd.appendChild(document.getElementById("map"));
  newWin.document.write(mapd);
I am getting the following as a response, which is not required result:
[object HTMLDivElement]
I have seen other possibilities involving geoprocessing printing task using ArcGIS Online maps which is not the case for me as I am using a map published as a map service and I have not interest in going through ArcGIS Online.
Please kindly advice !
Specs:
- ArcGIS Server 10.1 Enterprise.
- JS API 3.11
RobertScheitlin__GISP
Tracy,
  Here is some code I use in a custom dialog element to get the map image and replace a static placeholder I have in my dialog with the map image once it is ready and once the image is returned I enable my print button on that dialog.
this.map.infoWindow.hide();
        var oWid = this.map.width;
        var oHgt = this.map.height;
        var printTask = new PrintTask('print service url');
        var template = new PrintTemplate();
        this.imgHeight = (740/oWid) * oHgt;
        template.exportOptions = {
          width: 1542,
          height: (1542/oWid) * oHgt,
          dpi: 200
        template.format = "jpg";
        template.layout = "MAP_ONLY";
        template.preserveScale = false;
        template.showAttribution = false;
        var params = new PrintParameters();
        params.map = this.map;
        params.template = template;
        printTask.execute(params, lang.hitch(this, this.printResult));
printResult: function(rsltURL){
        var mapImg = domConstruct.toDom('<img src="'+rsltURL.url+'" border="0" style="width:740px;height:'+this.imgHeight+'px;"/>');
        domConstruct.place(mapImg, dom.byId('mapImgDiv'), 'replace');
        if(typeof has('android') === 'undefined'){
          domClass.replace(this.printBtnNode, 'myprint-btn', 'myprint-btn-loading');
          domAttr.set(this.printBtnNode, 'title', 'Print Tax Report...');
          this.own(on(this.printBtnNode, 'click', lang.hitch(this, this._printReport)));
TracySchloss
Honored Contributor
That works for me.  I figured it was a matter of waiting until there was output before proceeding.
