Print Widget
929
08-08-2012 06:50 AM
CraigMcDade
I'm working with the print widget sample and would like to configure it for the my services. I have started the PrintingTools service and changed the printer app url in the code to reflect properly for our server. However, when I run the code the print button is unresponsive. I haven't changed anything else in the code.
Looked through the API reference and saw the parameters need to be defined, but looks like there are some defaults already defined in server manager.
Any ideas. Obviously I'm a newbie and just getting my feet wet.
JianHuang
You may need to change the proxy page pointing to your local one.
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jshelp_start.htm#jshelp/ags_proxy.htm
