Print digit - errors when a popup graphic is displayed for a point feature
1029
09-18-2012 07:02 AM
by Anonymous User
Not applicable
Hello all,
The problem described in the title is fairly easy to reproduce.  If you share a map using the basic map template, click on a point to show the associated popup, then click the print button, the response reported in a Firebug console from the execute path for the print task REST endpoint will contain an error like so:
{"error":{"code":400,"message":"Unable to complete operation.","details":["Error executing tool.: Layer \"map_graphics\": �?\nFailed to execute (Export Web Map).\nFailed to execute (Export Web Map Task)."]}}
This is followed by a bunch of errors reported in the JavaScript console that look like:
Error: Unable to complete operation.
http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.2
Line 34
This only seems to occur when the popup is displayed for point features, and it appears to be specifically related to the graphic that is added to the map to highlight the clicked feature.  If you run the following line in the console after clicking on a point (while keeping the popup open), you can remove the highlight graphic from the map, then click the print button and everything will work fine:
map.graphics.clear();
You can easily try this by opening the following web map using the basic viewer template:
http://arcgis.com/apps/OnePane/basicviewer/index.html?webmap=69be6e1a1cae4fce9fbc44593b965f2f
If you click one of the trails on the map to show its popup, the print button will work fine.  If you click on one of the pavilions in the map (you may need to zoom in a bit due to their proximity to the trail), then try clicking the print button...no luck.
The best workaround we can think of at the moment is to customize the print button such that it will remove the graphic from the map, and/or close the popup, before actually executing the print task.
Is there a better solution for this?
derekswingley1
Thanks for the heads up and the simple repro case. We'll take a look and let you know the best way to work around this.
