Print Custom Text Symbols
4603
06-26-2015 01:42 AM
RyanSmith1
Hi Guys,
I have a tool which allows users to add text to the map. It works fine but when they try to do a print with the text they added to the map, the font size changes and so does the color of the text. How can i keep the selected the selected font size and color on the printout?
Regards,
Ryan
Tags (1)
thejuskambi
There some information here
Text Symbol to Export Web Map
BjornSvensson
Esri Alum
Ryan Smith​ Which version of the API are you using?  Could you share some code on how you're creating the TextSymbol?
RyanSmith1
Hi Bjorn,
I used the following example - Working with TextSymbol in the ArcGIS JavaScript API | ArcGIS Blog
I'm using api version 3.13 and the code i used to create the text symbol is:
map.on("click", function (evt) {
                        map.graphics.add(
                            new Graphic(
                                 new Point(evt.mapPoint.x, evt.mapPoint.y, map.spatialReference),
                                 new TextSymbol(dojo.byId("title").value).setColor(
                                 new Color(mapTextColor)).setFont(
                                 new Font(parseInt(dijit.byId("titlesize").value)).setWeight(Font["WEIGHT_BOLD"]))
Regards,
Ryan
SergioFernandez1
Hello Ryan,
Thanks for the code.  How are you printing the map after adding the text? With ExportWebMap? If so, how do you add the text to the ExportWebMap call?
RobertScheitlin__GISP
Sergio,
   All graphics on the map get added to the print export unless there is some error/issue that prevents this from occurring.
