Print a building with a rotation
1360
07-01-2014 08:14 AM
arnaudc
I have an application which uses ArcGis Server and ArcGis Javascript API.
I would like to know if there are some functions already defined in ArcGis Javascript API which enable rotations of the map before printing it. The angle of the rotation depends on the building printed.
Thanks for your answers
JeffPace
I am not aware of current support for rotation.
MuditAgarwal
You can use your own customized python script published as geoprocessing service taking angle of rotation as a parameter. You need to rotate data frame accordingly.
Mudit
JeffPace
Yes sorry, that is a good workflow.  I thought he was looking for something in the API
