Preset value in Editor widget in a JS app using the setValue
1085
11-21-2023 12:16 PM
LefterisKoumis
I have this simple JS app and trying to preset the value of a field. On this example is the Phone Number field but I want to know what am I doing wrong and I can't preset it using the setValue property.
This is the property:
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-FeatureForm-FeatureFormVi...
Here is the app.
JoelBennett
MVP Regular Contributor
I found adding a bit of asynchronous delay seems to do the trick:
editorVM.watch(['state', 'featureFormViewModel.feature', 'featureFormViewModel.state'], () => {
  if (editorVM.state == 'creating-features' && editorVM.featureFormViewModel.feature && editorVM.featureFormViewModel.state == 'ready') {
    window.setTimeout(function() {
      editorVM.featureFormViewModel.setValue('PhoneNumber', "999.999.999")
    }, 200);
You'll want to be careful this workflow doesn't inadvertently overwrite something the user manually enters; I didn't test for that kind of thing.
JoelBennett
    }, 200);
