Potential Code Issue - Seeking Verification
231
02-05-2026 11:32 PM
Yamakaze
I've spotted a potential code issue that appears to be a writing error, but I don't have test cases to verify what problems it might cause. Maybe I'm overthinking it, and I'd appreciate your confirmation.
version: @ArcGIS/core 4.34.8
file location:@arcgis\core\chunks\Envelope.js
class F {
  static getInstance() {
    return F.s_thisInstance
  constructor() {
    this.m_map = new Map,
      this.m_vd2D = new L(1),
      this.m_map.set(1, this.m_vd2D),
      this.m_vd3D = new L(3),
      this.m_map.set(3, this.m_vd2D) // **This line**
  GetVD2D() {
    return this.m_vd2D
  GetVD3D() {
    return this.m_vd3D
  FindOrAdd(t) {
    if (1 === t) return this.GetVD2D();
    if (3 === t) return this.GetVD3D();
    const e = this.m_map.get(t);
    if (e) return e;
    const s = new L(t);
    return this.m_map.set(t, s), s
On line 11:
. Based on the code from the previous two lines, I think the index 3 on line 11 should point to
this.m_vd3D
instead.
Tags (1)
