Possible bug in 4.23.2 when self-hosting assets / react
957
03-27-2022 11:24 AM
melgish
It looks like the 4.23 release of arcgis/core changed something that broke release builds using react.
I created a repo that demonstrates the error here https://github.com/melgish/map-issue
The map renders fine while in development mode, but when built for release, the map frame renders, but it never pulls any tiles.
If I downgrade to 4.22.2 and rebuild, everything works as expected.
ReneRubalcava
Esri Frequent Contributor
Not specific to local assets, but you need to update the browserlist for your production build in the package.json
https://github.com/Esri/jsapi-resources/tree/master/esm-samples/jsapi-create-react-app#misc
I'm surprised it worked in 4.22, but some of the down-compiling and babel helpers with the default browserlist will break some stuff. There's no errors, which is odd, but updating for evergreen browsers fixes this issue with CRA.
