Possible 4.0 beta 1 bug? (view.minZoom)
3484
09-25-2015 06:45 AM
TyroneBiggums
Please review the following code and let me know if I'm missing something. It appears that minZoom is ignored. A map appears but the user can zoom the map out all the way. I tried setting the minZoom property when I initialize a MapView instance. And, please notice that I tried setting minZoom after view is initialized. The line view.minZoom = 3; is commented out in the snippet because I tested both ways separately.
map = new Map({
    basemap: 'topo'
view = new MapView({
    container: id,
    map: map,
    center: [-100, 35],
    zoom: 4,
    minZoom: 3
// view.minZoom = 3;
view.ui.components = []; // toggles all default widgets off
Thank you,
D
Tags (1)
YannCabon
View constraints are now into a dedicated object.
MapView | API Reference | ArcGIS API for JavaScript
YannCabon
TyroneBiggums
Good call. My syntax for anyone else (or if someone else wants to advise a more efficient way):
     constraints: {
          minZoom: 3
