Portal API: find all webmaps
2739
08-05-2016 11:45 AM
RogerF
Is there anyway to find out all the webmaps from all the groups I have access to using ArcGIS JS API/Portal API ?
RobertScheitlin__GISP
Roger,
  See this thread for the answer:
How does one search for Web Map in an ArcGIS Portal?
RogerF
Thank you Robert for your quick reply. However I am looking to find out web maps only from groups I have access to in portal. The query type:"web map" AND access:shared provides me list of all web maps across all the groups. Is there anyway to filter that list to have web maps from groups I have access to.
ReneRubalcava
Esri Frequent Contributor
You can limit the results to a group, you can check out the ArcGIS Online docs to see what the parameters look like.
Use search—ArcGIS Online Help | ArcGIS
