Popups using MapImageLayer and LayerList Widget
3207
08-11-2017 12:04 PM
SarojThapa1
I have a mapservice that has 3 layers and each layer has sublayers. I am using mapImageLayer to call popups with the properties sublayers and popupTemplate as displayed below:
var displayLayer = new MapImageLayer({
  url: "RESTURL/endpoints",
  sublayers: [{
    title: "Gas Main",
    popupTemplate: {
      title: "Gas Main",
      content: [{
        type: "fields",
        fieldInfos: [
          {fieldName: "INSTALLDATE", visible: true, label: "Install Date", format: {dateFormat: "short-date"}},
          {fieldName: "SUBTYPECD", visible: true, label: "Type"}
The layers structure is:
Layer1 has index 0. Layer1 has two subLayers - sublayer1 with index 1 and sublayer2 with index 2.
Layer 2 has index 3.
I am using layerlist widget. When I have sublayers in the MapImageLayer, the layerlist displays all the layers at once without honoring the sublayers.
But when I do not have "sublayers" property in my MapImageLayer, the layerlist displays layers fine honoring the sublayers. I do not want to use feature layers just to make popups.
Any ideas on how to reconcile popup and layerlist widget.
Thanks
RobertScheitlin__GISP
Saroj,
   If reverting to 4.3 did not help you issue then it must be a different issue then I was thinking about.
Can you try setting the sublayer properties like this then:
var citiesLayer = layer.sublayers.getItemAt(3);
citiesLayer.title = "Gas Main";
citiesLayer.popupTemplate = {
      title: "Gas Main",
      content: [{
        type: "fields",
        fieldInfos: [
Saroj,
   Sublayer visibility is a known issue in 4.4 for now you will have to regress to 4.3.
SarojThapa1
Thanks Robert, Regressing to 4.3 still does not solve the issue. I will probably have to use feature layer to enable popups.
Saroj,
      title: "Gas Main",
      content: [{
        type: "fields",
        fieldInfos: [
Noah-Sager
Hi Saroj,
Did Robert's suggestion help you, or are you still having an issue with popups?
-Noah
SarojThapa1
Hi Noah, Yes Robert's suggestion helped. Forgot to mark as a Correct Answer.
