Popup template format not working
1523
06-25-2020 02:20 PM
TonyDaSilva1
I am trying to format the date in the popup on the map in ArcGIS for Javascript using the online documentation
Consider the following code:
        const fieldInfo = new FieldInfo({
            fieldName: "startDate",
            format: new FieldInfoFormat({ dateFormat: "long-month-day-year" })
        const popup = new PopupTemplate{
            title: "Project: <a href=\"http://pr/profile.aspx?pid={projectNumber}\" target=\"_blank\" >{projectName}</a>",
            content: "<p><b>Start Date:</b> {startDate}  <b>End Date</b>: {endDate}<p>"
            fieldInfos: [ fieldInfo ]
I can't seem to get the fieldInfos format to format the date. The date keeps coming out in the default format:
Any ideas to what is causing the issue?
for reference here are my dependencies:
"dependencies": {
    "@angular/animations": "^9.1.11",
    "@angular/cdk": "^9.2.4",
    "@angular/common": "^9.1.11",
    "@angular/compiler": "^9.1.11",
    "@angular/core": "^9.1.11",
    "@angular/forms": "^9.1.11",
    "@angular/localize": "^9.1.11",
    "@angular/material": "^9.2.4",
    "@angular/platform-browser": "^9.1.11",
    "@angular/platform-browser-dynamic": "^9.1.11",
    "@angular/router": "^9.1.11",
    "@ng-bootstrap/ng-bootstrap": "^6.1.0",
    "@types/arcgis-js-api": "^4.15.0",
    "classlist.js": "^1.1.20150312",
    "rxjs": "^6.5.5",
    "tslib": "^1.13.0",
    "web-animations-js": "^2.3.2",
    "zone.js": "^0.10.3"
  "devDependencies": {
    "@angular-builders/custom-webpack": "^8.4.1",
    "@angular-devkit/build-angular": "^0.900.7",
    "@angular/cli": "^9.1.9",
    "@angular/compiler-cli": "^9.1.11",
    "@angular/language-service": "^9.1.11",
    "@arcgis/webpack-plugin": "^4.15.0",
    "@types/jasmine": "~3.3.8",
    "@types/jasminewd2": "^2.0.8",
    "@types/node": "^12.12.47",
    "codelyzer": "^5.2.2",
    "jasmine-core": "~3.4.0",
    "jasmine-spec-reporter": "~4.2.1",
    "karma": "~4.1.0",
    "karma-chrome-launcher": "~2.2.0",
    "karma-coverage-istanbul-reporter": "~2.0.1",
    "karma-jasmine": "~2.0.1",
    "karma-jasmine-html-reporter": "^1.5.4",
    "protractor": "^5.4.4",
    "ts-node": "~7.0.0",
    "tslint": "~5.15.0",
    "typescript": "~3.7.5"
JackFairfield
I would recommend simply switching the content property to a function like this:
const popup = new PopupTemplate( {
  content: ({graphic}) => {
    const { startDate, endDate } = graphic.attributes;
    const start = `${startDate.getFullYear()}-${startDate.getMonth()}-${startDate.getDate()}`;
    const end = `${endDate.getFullYear()}-${endDate.getMonth()}-${endDate.getDate()}`;
    return `<p><b>Start Date:</b> ${start} <b>End Date</b>: ${end}<p>`;
I find it much easier to just create my own custom function for adjusting the field values instead of using the fieldInfos objects.
