Popup is not displaying queried Related Records
1526
02-18-2013 12:18 PM
IreneGM
I have a Feature Service in my ArcGIS for Server 10.1 that displays features in a concrete world region. This same service, has a relationship with a table in my database, so every feature represented in the map, has attached several record I would like to display. At first, just for practising, I tried this example that shows the related records in a side grid, but then I decide it would be better and compact to display those records on a Popup, as this example shows.
But it turns out that after querying the related records and making sure that I have received them correctly, putting them on an Array of Features (or Deferred) and passing all those results to the Popup.setFeatures(Features[] | Deferred[]) the results are not displaying in the popup. I searched on this same forum and on GIS StackExchange and found some people similar problems, but I do not see a clear workaround.
The funny thing is that the title part of the Popup presents the counter of the total number of related records for that feature, so I think that Popup does receive the Array of Features. I am attaching an image to make it clear:
[ATTACH=CONFIG]21916[/ATTACH]
Therefore...is there anything wrong in my features? They are the result of a queryRelatedFeatures so I am not sure of how much can I modify this output to match the Popup. And, in the end, if this function returns an array of features, why setFeatures() is not displying them? Something missing? Maybe a parameter?
Here is my code:
     dojo.connect(map,"onClick",function(evt){
          var query = new esri.tasks.Query();
          query.geometry = pointToExtent(map,evt.mapPoint,10);
          var deferred = featureLayer.selectFeatures(query,esri.layers.FeatureLayer.SELECTION_NEW);
          deferred.then(function (results) {
           dojo.forEach(results, function(res){
            var relatedTopsQuery = new esri.tasks.RelationshipQuery();
            relatedTopsQuery.outFields = ["*"];
            relatedTopsQuery.relationshipId = 0;
            relatedTopsQuery.objectIds = [res.attributes['OBJECTID']];
            reldeferred = featureLayer.queryRelatedFeatures(relatedTopsQuery, function(relatedRecords) {
              var fset = relatedRecords[res.attributes['OBJECTID']];
              dojo.forEach(fset.features, function(feature){
               feature.attributes.StartDate = Date(feature.attributes.StartDate).toLocaleString();
              feature.attributes.EndDate = Date(feature.attributes.EndDate).toLocaleString();
              feature.setGeometry(evt.mapPoint);
              featureArray.push(feature);
            map.infoWindow.setFeatures(featureArray);
              map.infoWindow.show(evt.mapPoint);
              featureArray = [];
            }); // close related deferred
   }); // close for each
   }); // close deferred then
I tried to pass to the setFeatures function the array of features I am building and the deferred once it is created. But the output is similar: the array returns what the image shows and the deferred something like "No information available".
I have been struggling with this several days and I am completely stuck, please, can anyone provide some help?  🙂
Thanks to all!
NathanaelVaughan
I have a similar issue. I've tried multiple time to rearrange the setting of the info template and nesting of the resulting deferreds. In my case, I am building an HTML table of the text results to display in the InfoWindow/Popup. I can get "dummy" text to display effectively in the InfoWindow, but not the table generated by my secondary-deferred-result.
Anyone have any suggestions? This can't be a very unique situation.
I would do a standard join, except the data has a many-tabular-values to one-spatial-value relationship that I am trying to summarize.
