Popup focus
4743
10
03-10-2017 06:46 AM
MathewSuran
I have a point feature that when clicked on, generates a popup with a graphic.  The graphic is rather large so the whole popup is always cut off.  I looked through the documentation and I am not really sure on what to call it so I don't really know what I am looking for, but I am looking to have the map resize to automatically when a popup is active to be able to refocus on the popup to show the whole thing.  Anyone have any idea?
RobertScheitlin__GISP
Mathew,
  You can use the Popup objects reposition method that is specifically designed for that:
https://developers.arcgis.com/javascript/3/jsapi/popup-amd.html#reposition
MathewSuran
Ok, thanks.  How would this work for a PopupTemplate?  See example below:
currentLayer.on("click", function(evt) {
console.log(evt);
 featureId= evt.graphic.attributes.OBJECTID;
 currentLayer.queryAttachmentInfos(featureId, function(attach) {
 featureUrl=attach[0].url;
 currenttemplate = new PopupTemplate({
 title: "Current",
 fieldInfos: [{
 fieldName: "Name",
 label: "Name: ",
 visible: true
 fieldName: "X",
 label: "X: ",
 visible: true
 fieldName: "Y",
 label: "Y: ",
 visible: true
 mediaInfos:[{ //define the image
 "title": "",
 "caption": "",
 "type":"image",
 "value":{
 "sourceURL": featureUrl
 currentLayer.infoTemplate=currenttemplate;
 function(errback) {
 console.log(errback);
Mathew,
  For that you will have to attach and event to the Popups show event and then call the repostion method.
MathewSuran
Would you be able to provide an example?
Mathew,
  Something like:
map.infoWindow.on("show", function(){
  setTimeout(function(){
    map.infoWindow.reposition();
  }, 500);
MathewSuran
Maybe I am not placing it in the correct position, but it is not working.  I would want to place this after the layers and templates get loaded, correct?
JimNoel
Can you give an example for how to do the same in 4.3?  There doesn't seem to be a "show" event for the 4.3 Popup class.  Is this accessed in a different way?
Jim,
   In 4.x API you would watch the view.popup.visible property
JimNoel
So my problem is actually a little different from Mathew's.  If the point feature is close to the edge of the display so that the popup in its original position extends beyond the display, the map pans to fit the popup.  I want to keep the original map extent, and move the popup to fit the current extent.  (If it makes a difference, the popup is triggered by a mouseover rather than a mouse click, using MapView.hitTest)
I tried watching the view.popup.visible property and using the reposition method in the callback, but that didn't work.
Question:  Will the callback function for view.popup.visible come up before the map extent changes?
Alternatively, is there some other setting I can use to prevent the map extent from changing?  Thanks.
