Popup and Layerlist
5401
12
07-31-2019 06:29 AM
FengYu
I want to combine the popup function (identify the pixel values or feature attributes for MapService) and layerlist widget, potentially add some other widgets. I follow the example for the ESRI's javascript API description but the widgets seem to be misplaced and the popup does not show in the current location. The content plane has been set to the right and the widgets to the left, but still not working. I would appreciate any inputs regarding this issue.
<!DOCTYPE html>
<html>
 <head>
 <!--The viewport meta tag is used to improve the presentation and behavior of the samples
 on iOS devices-->
 <title>soil map</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.29/esri/themes/calcite/esri/esri.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.29/dijit/themes/claro/claro.css">
 <style>
 html, body, .container, #map {
 height:100%;
 width:100%;
 margin:0;
 padding:0;
 margin:0;
 font-family: "Open Sans";
 #map {
 padding:0;
 #layerListPane{
 width:25%;
 .esriLayer{
 background-color: #fff;
 .esriLayerList .esriList{
 border-top:none;
 .esriLayerList .esriTitle {
 border-bottom:none;
 .esriLayerList .esriList ul{
 #search {
 display: block;
 position: absolute;
 z-index: 3;
 top: 20px;
 left: 75px;
 #HomeButton {
 position: absolute;
 top: 100px;
 left: 15px;
 z-index: 50;
 </style>
 <script>var dojoConfig = { parseOnLoad: true };</script>
 <script src="http://js.arcgis.com/3.29/"></script>
 <script>
 require([
 "esri/dijit/Popup",
 "esri/symbols/SimpleFillSymbol",
 "esri/symbols/SimpleLineSymbol",
 "esri/Color",
 "dojo/dom-construct",
 "esri/map",
 "esri/dijit/HomeButton",
 "esri/layers/ArcGISDynamicMapServiceLayer",
 "esri/dijit/LayerList",
 "esri/dijit/Search",
 "esri/dijit/Legend",
 "esri/dijit/Scalebar",
 "esri/tasks/IdentifyTask",
 "esri/tasks/IdentifyParameters",
 "dojo/_base/array",
 "esri/InfoTemplate",
 "dojo/dom",
 "dijit/layout/BorderContainer",
 "dijit/layout/ContentPane",
 "dojo/domReady!"
 ], function (
 Popup, SimpleFillSymbol, SimpleLineSymbol, Color, domConstruct,
 Map, HomeButton, ArcGISDynamicMapServiceLayer, LayerList, Search, Legend, Scalebar,
 IdentifyTask, IdentifyParameters, arrayUtils, InfoTemplate,
 dom
 var map, identifyTask, identifyParams;
var popup = new Popup({
 fillSymbol: new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
 new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
 new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.25]))
 }, domConstruct.create("div"));
 map = new Map("map", {
 basemap: "topo",
 center: [-90.125, 40],
 zoom: 8,
 infoWindow: popup
map.on("load", mapReady);
var rasterURL1 = "https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer";
var operationalLayer1 = new ArcGISDynamicMapServiceLayer(rasterURL1, { opacity: .80 });
 map.addLayers([operationalLayer1]);
var layerList = new LayerList({
 map: map,
 layers: [{
 layer: operationalLayer1,
 showLegend: true,
 showSubLayers: false,
 showOpacitySlider: true
 },"layerList");
 layerList.startup();
var rasterURL2 = "https://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Petroleum/KGS_OilGasFields_Kansas/MapServer";
 map.addLayer(new ArcGISDynamicMapServiceLayer(rasterURL2,
 { opacity: .90 }));
 var search = new Search({
 map: map,
 }, dom.byId("search"));
search.startup();
var home = new HomeButton({
 map: map
 }, "HomeButton");
 home.startup();
var scalebar = new Scalebar({
 map: map,
 scalebarUnit: "dual"
 scalebar.startup();
 function mapReady () {
 map.on("click", executeIdentifyTask);
 //create identify tasks and setup parameters
 identifyTask = new IdentifyTask(rasterURL1);
identifyParams = new IdentifyParameters();
 identifyParams.tolerance = 1;
 identifyParams.returnGeometry = true;
 identifyParams.layerIds = [0,1];
 identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_ALL;
 identifyParams.width = map.width;
 identifyParams.height = map.height;
function executeIdentifyTask (event) {
 identifyParams.geometry = event.mapPoint;
 identifyParams.mapExtent = map.extent;
var deferred = identifyTask
 .execute(identifyParams);
 deferred.addCallback(function (response) {
return arrayUtils.map(response, function (result) {
 var feature = result.feature;
 var layerName = result.layerName;
 //alert(result);
 feature.attributes.layerName = layerName;
 if (layerName === 'Census Block Points') {
 var taxParcelTemplate = new InfoTemplate(layerName,
 "the oject value is: " + feature.attributes['STATE_FIPS']);
 feature.setInfoTemplate(taxParcelTemplate);
 else if (layerName === 'KS_FIELD_OUTLINES_SPRING2005_GEONAD27') {
 "the oject value is: : " + feature.attributes['FIELD_NAME']);
 return feature;
map.infoWindow.setFeatures([deferred]);
 map.infoWindow.show(event.mapPoint);
 </script>
 </head>
<body class="claro">
<div class="container" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false">
 <div id="layerListPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'">
 <div id="layerList"></div>
 </div>
<div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"></div>
<div id="search" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'"></div>
<div id="legendDiv" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'"></div>
<div id="HomeButton" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'"></div>
</div>
</body>
</html>
FengYu
Robert,
Thanks, but I still do not understand the concept of async tasks. I am new to javascript and is there any simpler way to do this? What I need is just to provide users with toggle on/off (by click) for layers and popup for currently toggled layers.
RobertScheitlin__GISP
Feng,
  Sorry I not sure how I could provide any more help short of writing the code for you.
FengYu
Robert,
I found another example from this thread and try to incorporate into my code but it does not work correctly. I will create a new question and would appreciate your inputs. Thanks.
https://community.esri.com/thread/94154
Feng
