<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>Feature Layer Only Map</title>
<link rel="stylesheet" href="http://desktop101.ksrsac.com/KSRSAC/arcgis_js_api/library/3.9/3.9/js/dojo/dijit/themes/claro/claro.c...">
<link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css">
<style>
html,
body {
height: 100%;
width: 100%;
margin: 0;
body {
background-color: #FFF;
overflow: hidden;
font-family: "Trebuchet MS";
#header {
background-image: url(http://desktop101.ksrsac.com/KSRSAC/LefttPane/images/banner.jpg);
background-repeat: repeat-x;
border: solid 4px #224a54;
color: #FFF;
font-size: 18pt;
text-align: left;
font-weight: 700;
height: 70px;
margin: 2px;
#leftPane {
color: #3f3f3f;
border: solid 2px #224a54;
width: 20%;
margin: 5px;
padding: 2px;
#map {
height: 100%;
width: 100%;
margin: 0;
padding: 0;
.dijitTabInnerDiv {
background-color: #ecefe4;
#tabs {
padding: 5px;
#HomeButton {
position: absolute;
top: 200px;
left: 280px;
z-index: 50;
</style>
<script>
dojoConfig = {
parseOnLoad: true
</script>
<script src="http://desktop101.ksrsac.com/KSRSAC/arcgis_js_api/library/3.9/3.9/js/dojo/dojo/dojo.js"></script>
<script src="http://js.arcgis.com/3.9/"></script>
<script>
require([
"dojo/dom-construct",
"esri/map",
"esri/layers/FeatureLayer",
"esri/geometry/Extent",
"esri/InfoTemplate",
"esri/dijit/HomeButton",
"esri/dijit/OverviewMap",
"dojo/parser",
"dojo/store/Memory",
"dijit/form/ComboBox",
"esri/tasks/QueryTask",
"esri/tasks/Query",
"dijit/layout/BorderContainer",
"dijit/layout/TabContainer",
"dijit/layout/ContentPane",
"dojo/domReady!"
], function (
domConstruct,
Map,
FeatureLayer,
Extent,
InfoTemplate,
HomeButton,
OverviewMap,
parser,
Memory,
ComboBox
parser.parse();
var bounds = new Extent({
"xmin": 7583508.66876001,
"ymin": 754519.306341084,
"xmax": 10843390.8045407,
"ymax": 4451565.92247309,
"spatialReference": {
"wkid": 3857
var map = new Map("map", {
extent: bounds
var url = "http://164.100.133.66/ArcGIS/rest/services/Basemap/StateBasemap/MapServer/6";
var template = new InfoTemplate("Tank Information System", "<tr>State Name: <td>${STATE}</tr></td><br><tr>Objectid:<td>${OBJECTID}</tr></td><br><tr>Shape length:<td>${Shape_Length}</tr></td><br><tr>Shape Area:<td>${Shape_Area}sq Meters</tr></td>");
var fl = new FeatureLayer(url, {
infoTemplate: template
//var overviewMapDijit = new OverviewMap({ map: map, visible: true});
var home = new HomeButton({
map: map
}, "HomeButton");
//QUERY TASK FOR DROP DOWN
function init() {
queryTask = new esri.tasks.QueryTask("http://164.100.133.66/ArcGIS/rest/services/Basemap/StateBasemap/MapServer/6");
var query = new Query();
query = new esri.tasks.Query();
query.returnGeometry = false;
query.outFields = ["STATE"];
query.where = "STATE<> ''";
queryTask.execute(query, populateList);
function populateList(results) {
//Populate the ComboBox with unique values
var zone;
var values = [];
var testVals = {};
//Add option to display all zoning types to the ComboBox
values.push({name: "ALL"
//Loop through the QueryTask results and populate an array
//with the unique values
var features = results.features;
dojo.forEach(features, function (feature) {
zone = feature.attributes.STATE;
if (!testVals[zone]) {
testVals[zone] = true;
values.push({ name: zone});
//Create a ItemFileReadStore and use it for the
//ComboBox's data source
var dataItems = {
identifier: 'name',
label: 'name',
items: values
var store = new Memory({data: dataItems});
dijit.byId("mySelect").store = store;
map.addLayer(fl);
//overviewMapDijit.startup();
home.startup();
init.startup();
dojo.addOnLoad(init);
</script>
</head>
<body class="claro">
<div id="mainWindow" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'" style="width:100%; height:100%;">
<div id="header" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'">
<div id="title">"Tank Information System"
</div>
</div>
<div data-dojo-type="dijit.layout.ContentPane" id="leftPane" data-dojo-props="region:'left'">
<div data-dojo-type="dijit.layout.TabContainer">
<div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="title:'Table of Content', selected:'true'">
Content for the first tab
</div>
<div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="title:'Search'">
Content for the second tab
<select id="mySelect" dojoType="ComboBox" style="width:200px;font-size:16px;"
autoComplete="true"
forceValidOption="false"
value="Select Zoning Type"
onchange="applyLayerDef(this)" >
</select>
</div>
</div>
</div>
<div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"></div>
<div id="footer" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'bottom'">
<span id="dataSource">
</span>
</div>
<div id="HomeButton"></div>
</div>
</body>
</html>
First, once you past in code, please use the advanced editor, choose the double arrow, and use syntax highlighting to format as javascript
second, as an example
<select data-dojo-type="dijit/form/FilteringSelect" id="printOrientation" style="width:140px;">
<option value="p" selected>Portrait</option>
<option value="l">Landscape</option>
</select> Orientation<br>
No , I Want to Populate the attribute values to the combo box and when user selects any one of the listed values it should get zoomed to that polygon.
then you can attach an onchange event to the box . In my example
registry.byId("printOrientation").onChange=function(){
//do your zoom to feature
